10hp diesel Outboards from India
foilcats
foilcats: 10hp diesel Outboards from India
Technical Specifications of STAR BD10 Diesel Outboard Motor 10 HP, single cylinder, four stroke, air-cooled, transom operated, long shaft, rope start, manual tilt arrangement diesel outboard motor. 1. Propeller Shaft Power (kw/HP) : 7.35 / 10 2. Model : BD 10 3. Rated Speed (rpm) : 3,600 4. Bore/Stroke (mm) : 86 / 70 5. Type : Single Cyl, 4 Stroke, forced air-cooling 6. Displacement (L) : 406 cc 7. Fuel consumption at Rated Speed (g/kw.h) : 285.7 ( Approx. 2.5 ltrs/hour) 8. Starting System : Manual / Electric 9. Gear Mode : Shaft gearing 10. Gear ratio : 2 : 1 11. Gear Shift : F N R 12. Net Weight (kg) : 72 kg 13. Overall Dimensions - L x W x H (mm) : 1,340 x 650 x 550
Posted by: foilcats - website: http://www.seahull.com
foilcats, Apr 6, 2007
  • There are no comments to display.
  • Category:
    Propulsion
    foilcats
