Old 05-28-2009, 03:29 AM
fcfc fcfc is online now
Rep: 333 Posts: 677
Sail forces and sail plan ?
Is there books or papers that give practical formulas to get CL CD (or drive/side force coefficient) from a sail plan ?
I have "Principles of Yacht Design 3rd" , It give some models for sail aerodynamics from G Hazen, but it is around 30 years old.
For instance, what is not dealt with is fractional rig (3/4 , .. 9/10, masthead), jib overlap (105% , 135%,150%), boom heigh above sheer, presence of a genoa furler etc ...
Thanks.
Old 06-03-2009, 03:02 AM
Rep: 333 Posts: 677
Have someone read "Sailing yacht design: Theory" from Claughton, 2nd edition 2006 ?
Are there usable formulaes in this book, for sail plan and rigs ?
Usable formulae for me are with numerical application and units.
I have found some papers that speak more or less with what I want, but they just give the general, without giving the value of constants and units. So they are strictly useless from a sail plan design point.
Thanks.
Old 06-03-2009, 11:44 AM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2006 Posts: 1,638
fc....
In Sailing Yacht Design: Theory, Claughton addresses CL and CD in a chapter on Velocity Prediction Programs...but presents the IMS data from Hazen. He does present some basic equations on dealing with sail sets (two or more sails flying together). He also references an equation from Glauert, H., Airfoil and Airscrew Theory, 1959....
Claughton also references a paper by Larsson, L., Numerical predictions of the flow and resistance components of sailing yachts, 1987.
Old 06-03-2009, 12:58 PM
Rep: 1397 Posts: 7,215
Most formulas for sails are very simplistic. Sails are soft foils which means they are constantly changing. The static models are very rough approximations. Besides the adjustments that can be done to the sail trim and the combinations thereof, the movement of the boat changes the direction of the air flow.
Old 06-03-2009, 11:01 PM
Rep: 2891 Posts: 8,789
100 sq. ft of sail area is about 2 HP.
Old 06-04-2009, 03:20 AM
Rep: 333 Posts: 677
You can have a very good paper on hull and rig drag there http://heikki.org/publications/ThesisHansen.pdf (equation 3.11 and 3.12)
My goal was to have a better estimation of drive and side forces.
For hydrodynamic estimation, with delft papers, you have very good sources, but for aerodynamic estimation, it is much more limited.
I know a (small) professional builder, who tried to beefed up a known old design (sold in thousands) with marginal performances in stronger winds. The boat is a daggerboard. The idea was to sell an "upgrade" kit. He put kind of bulb, and increased strengh accordingly in centerboard box and rig. Just to find in sea trials that the boat still had weak performances upwind in stronger winds. Acceptable heel and speed, but too much leeway. After investigation, and contacting a naval architect, he just found the keel was stalling. Not enough lateral surface to cope with the sails side force with increased stability.
Old 06-04-2009, 05:10 AM
terhohalme's Avatar
terhohalme terhohalme is offline
Rep: 478 Posts: 484
Is this any help for you?
http://www.hiswasymposium.com/pdf/20...%20Fossati.pdf
Other papers of the same symposium here:
http://www.hiswasymposium.com/symposium_papers.asp
Only shared knowledge can grow.
Old 06-04-2009, 06:13 AM
Rep: 333 Posts: 677
I have already read them.
"The “fine tuning” of
the aerodynamic coefficients was done analyzing similar figures for the other two boats."
It explains all, but do not give a single figure for coefficients. So it is not practically usable.
The result is a mutidimentional surface. Heff is a function of (roach, genoa overlap, fractionality) , Figures 2.11 to 2.13 gives you some "cut" in the surface, but not enough to rebuild the surface. (2.11 2.12 are the same numbers shown differently).
Old 06-04-2009, 12:10 PM
Rep: 1623 Posts: 1,483
Have you read Aero-Hydrodynamics of Sailing by Marchaj? It is fairly good discussion on why there is no "F=C*A*V^2" equation for sails and the problems of model to real correlation.
Old 06-05-2009, 03:36 AM
terhohalme's Avatar
Rep: 478 Posts: 484
What makes you think that there is a simply equation for a complex phenomenom?
Old 06-05-2009, 04:40 AM
Rep: 333 Posts: 677
For Marchaj book, it is not available on amazon. There are only (old) used editions available. Are there differences between 1979 to 2000 editions, or they are just reprints ?
For sail physics , I agree if equations do exist, they are very complex to solve. Kind of CFD. It is not within my reach.
What I was looking is more of regression analysis. Which are very basic, even if they have many parameters. For instance, Fossati paper contains an atempt to do a regression analysis of one parameter Effective rig heigh, rather hard to measure, from 3 parameters easy to measure (overlap, roach and fractionnality).
For Delft series hydrodynamic forces, real physical equations are very complex. But the regression analysis is very simple, with rather accurate predictions in the domain range (at least accurate enough for me) . I was simply hoping something similar for sails.
Old 06-05-2009, 06:36 AM
Previous Member
Rep: 0 Posts: 0
There is considerable discussion on sails in various threads. Here is a sample:
multi element foil sections?
In post #5 I show how a multi-element sail can be set up in JavaFoil.
JavaFoil is quite easy to use. If you take the time to get a grasp on it then you will learn quite a lot about sails.
Rick W
Old 06-05-2009, 06:53 AM
Previous Member
Rep: 0 Posts: 0
If you want to make some simple analysis then work on a lift to drag of say 6 for a fractional rig per attached.
Rick W
Old 06-05-2009, 07:31 AM
daiquiri's Avatar
Engineering and Design
Rep: 2340 Posts: 2,470
Beware of using JavaFoil for the analysis of very thin airfoils.
JavaFoil is based on a vortex panel method with is a part of the so-called "Thin Airfoil Theory".
Thin Airfoil Theory is known for giving very good results for nearly all types of airfoils (if a correct boundary-layer correction is applied)... except for thin airfoils.
That's because thin airfoils are subject to leading-edge flow separation at any finite angle of attack (AoA). The only case when it doesn't happen is when they are set at the ideal AoA, which is the one you have when fluid streamlines are perfectly parallel to the airfoil at the leading edge.
Standard boundary-layer corrections (such as those used by JavaFoil) cannot cope with that situation with an acceptable accuracy and therefore are not valid for thin airfoils at a finite AoA.
Old 06-05-2009, 08:07 AM
Previous Member
Rep: 0 Posts: 0
I have always used tufts on sails to ensure attached flow except when pushing very high trying to make a windward mark. So confident I have attached flow.
I expect for these conditions the JavaFoil analysis is quite adequate but if you have better analysis please make an offering.
Rick W
Sail plan RHough Wiki 10 08-24-2009 06:52 AM
Sail Forces...need help. alimert Sailboats 1 04-09-2008 08:19 AM
Sail Plan Help TimClark Sailboats 4 01-31-2007 08:11 PM
Sail Forces...again nemo Sailboats 5 02-15-2004 09:42 PM
sail forces, how to calculate Guest Sailboats 0 01-04-2004 01:36 PM
