Old 01-21-2009, 09:39 AM
sigurd sigurd is offline
Pompuous Pangolin
Rep: 43 Posts: 624
multi element foil sections?
I am looking for multi element foil section coordinates, measurements/predictions - I find lots of nice pics and graphs of CL 4-5 but no coords...
especially low Reynolds sections would be interesting.
Old 01-21-2009, 04:39 PM
Rep: 527 Posts: 792
Get a copy of Profili (shareware) and see what they've got.
Jimbo
Old 01-22-2009, 02:22 AM
Pompuous Pangolin
Rep: 43 Posts: 624
thanks, will do.
Old 01-23-2009, 12:31 AM
aka Terry Haines
Rep: 1682 Posts: 2,817
This any help?
http://www.ppart.de/aerodynamics/profiles/NACA4.html
Dances with Turkeys
Old 01-23-2009, 02:20 AM
Previous Member
Rep: 0 Posts: 0
JavaFoil can generate a whole range of foil profiles and these can be scaled and shifted into multi-element configurations per attached. Just google JavaFoil and run the Applet. If you know a little about foils you should be able to get useful results from it.
Rick W
Old 01-24-2009, 02:07 AM
Pompuous Pangolin
Rep: 43 Posts: 624
that was fun. The NACA generator was cool too.
Old 01-24-2009, 03:00 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1528 Posts: 5,518
is there a NACA generator that you can dial in a NACA number and play with it and the generator will give drag and lift per square foot.
Some NACA are suggested to be low drag but what. All foils have drag but the trick is to get the drag within your power supply and give lift to reduse wetted area. This should result in better performance.
I am designing some ,--I call winglets to fit under the two hulls ,--not all the way across as a Hysucat.
I intend to make these by eye and hand out of 1 inch ply and expoxy them up to the hull after the bulbous bows.
If they work I will improve on design and materials.
The cat is the seawind ventura 44 500HP.
Old 01-24-2009, 01:45 PM
Pompuous Pangolin
Rep: 43 Posts: 624
I'm no expert but I hear some shapes are more demanding wrt accuracy and dirt. (The NACA 4digit section are supposed to be forgiving I think?)
Javafoil generates NACA, and analyses it. You can also adjust the level of dirt and bugs (doesn't say which bugs) in the simulation.
Profili I found useful as a database to look at and export sections, the analysis are there but you have to pay the pro version to use it.
Finite Element Analysis Software Casper Software 9 11-21-2009 06:59 PM
Finite element software CGN Software 2 07-12-2008 01:25 AM
FEA, Finite Element Anaylsis brian eiland Software 17 04-02-2006 12:05 PM
Asymmetrical+Foil vs Symmetrical Multi skypoke Boat Design 13 08-21-2005 08:42 PM
Finite Element Analysis of hulls Francesco Software 0 10-05-2001 12:49 PM
