Old 01-09-2011, 04:59 PM
rberrey rberrey is offline
Rep: 69 Posts: 287
daggerboard rudder
I am about to start a build on a tristar 31, I would like to have a daggerboard rudder on it but there are only kick up and spade rudders designed for it. What are the chances I can just adapt a F-33 rudder onto it? rick
Old 01-09-2011, 07:12 PM
Rep: 3125 Posts: 9,403
. . . Why?
Old 01-09-2011, 07:36 PM
Rep: 69 Posts: 287
If I use a spade rudder I end up with a 30" draft and cant beach , with a kickup rudder I can beach and have a 19" draft. I want an inboard diesel, I've been told it will be less efficiant with the kickup. I thought a daggerboard rudder might be a good compromise. rick
Old 01-09-2011, 09:04 PM
Rep: 118 Posts: 820
Nice boat! You'll have to increase the transom thickness for a outboard rudder. Why don't you call Ed to see if he has anything?
Old 01-10-2011, 05:40 PM
Rep: 69 Posts: 287
I wrote Ed about it a month or so ago, sometimes Ed is out of town and it takes some time for him to answer. I know all he has is the spade and kickup rudder designed for the 31. There is a picture of a daggerboard rudder on a 27'9" ( Quility Time ) on a web site, but I could,nt get in touch with the owner. I will use renicell E240 for the transom and increase the thickness, Ed told me I had to do that with the kickup rudder. rick
Old 01-10-2011, 10:49 PM
Rep: 118 Posts: 820
An F-boat rudder would work. You could also adapt a Newick rudder. They swing aft through a trunk and can be either spade or skeg depending on the design. Plans for many of Newick's designs are in the Mariners Museum and for a nominal fee they will print out what you request but you have to have an idea of what you are after because the collection isn't completely sorted through yet. Follow the directions on the museum website to contact the photography department and archives. A Tricia rudder for a skeg rudder or Echo 1 for a spade are a place to start. Those designs are 36 feet, Val 1 at 31 feet had a skeg unit as well.
Old 01-11-2011, 05:47 PM
Rep: 69 Posts: 287
Thanks cavalier
Old 01-15-2011, 11:07 AM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
The daggerboard rudder has the disadvantage that it doesn't kick back if you hit something inadvertently.
Does your boat already have a kickup rudder in a cassette? If so, does it have a fixed portion above the movable rudder blade like this?
The fixed portion allows the rudder to still be steerable when kicked back.
The efficiency of the rudder really has to do with how deep it is. I don't see any reason why a kickup rudder would have to be any less efficient than a daggerboard or spade rudder. You just have to make sure the structure and kickup mechanism is up to handling the higher moments of a deeper rudder.
The one drawback I've experienced with the kickup rudder and inboard diesel above is the rudder has a tapered planform with all the taper in the leading edge. Which I believe is the most hydrodynamically efficient way to do it. But it also means there is more area ahead of the pivot at the root, which is blown by the prop. The result is a severely over-balanced rudder when under power. You really have to stay on top of it, and can't let the tiller go for an instant when powering at speed. But it's just something to get used to and it's fine with the autopilot on.
Tom Speer
Old 01-15-2011, 12:44 PM
Rep: 69 Posts: 287
I,ll be building the boat soon so no rudder at all right now. The rudder you show would work really well but as a home builder it might be a bit complecated. My options are a kick up skeg rudder or a fixed spade rudder. The F boat daggerboard rudders now have a kickup version. I am told where the rudder is located distance wise to the prop will affect the efficiency. What I am looking at is which rudder is best with an inboard, and also allow for shallow draft. rick
Old 01-16-2011, 07:17 AM
pogo's Avatar
pogo pogo is offline
Rep: 17 Posts: 57
There is a solution, please look at pix and read posting 53.
Planing Catamaran!
http://img638.imageshack.us/img638/5861/02825g.jpg
pogo
Immer handflach Wasser unter`m Schwertschlitz !
Old 01-16-2011, 08:42 AM
Rep: 69 Posts: 287
That is a nice looking rudder system pogo, how would I come up with the right size rudder for my boat, would I be able to use my daggerboard size to come up with the rudder size? thanks rick
Old 01-20-2011, 04:01 PM
sandy daugherty's Avatar
sandy daugherty sandy daugherty is offline
Rep: 52 Posts: 132
Uwe Jaspersen, the South African builder of the first Gunboat, and designer of several serious go-fasts, came up with a unique rudder design. It is a daggerboard that slides up or down in a cylinder that fits a barrel in the back of the boat. It was featured in the Gun Boat 60 at the Annapolis boat show. He used the same concept in his Moxie 34 from two years ago. Elegant engineering.
This offers the advantage of placing the rudder exactly where it works best relative to a propeller, is fully balanced hydrodynamically, and uses no complicated rigging.
Old 01-20-2011, 04:49 PM
jamez jamez is offline
Rep: 184 Posts: 272
Crowther barrel rudder c. mid 1990s.
Old 01-21-2011, 09:59 AM
Rep: 52 Posts: 132
Wow! I am surprised. I guess it's true, "there is nothing new under the sun."
Old 01-21-2011, 11:30 AM
Rep: 118 Posts: 820
What did they use for bearings?
Proa Questions: Rudder/Daggerboard Placement Inquisitor Multihulls 0 07-02-2010 11:23 AM
Carbon layup for a rudder and daggerboard usa1154 Fiberglass and Composite Boat Building 1 01-25-2006 12:14 AM
Rudder and daggerboard profiles. Sailboats 37 08-31-2004 12:58 AM
Help!!!! ( daggerboard construction or daggerboard design ) 01639770993 Boat Design 1 12-29-2003 12:56 PM
