Go Back   Boat Design Forums > Design > Propulsion > Diesel Engines
Old 12-08-2008, 07:00 AM
Chris Bretter's Avatar
Chris Bretter Chris Bretter is offline
Zaphod
Rep: 55 Posts: 45
Dropdown Longshaft for Wharram Catamaran
Hi all
I am starting to build a 38 ft Wharram i would like to use a centre mounted Nissan SD22 with a 2-1 reduction box and a dropdown longshaft. All fairly simple Has anyone any ideas.Also perhaps a ducted prop with a rudder to assist low speed manouvering.You guys think out of the box.
Regards Chris South Africa
Old 12-08-2008, 07:50 AM
boat fan's Avatar
boat fan boat fan is offline
Rep: 357 Posts: 679
Hello Chris , I don`t know if you have seen this :
http://www.themultihull.com/wharram/p52je2.htm
It`s a larger custom wharram , but may be of interest.
Another :
http://www.themultihull.com/wharram3/bk6.htm
http://www.themultihull.net/kd1.htm
Regards B F
Old 12-08-2008, 08:53 AM
Zaphod
Rep: 55 Posts: 45
Hi BF I had looked on the multihull site but not seen these pics.Have you tried anything like this thanks Chris
Old 12-08-2008, 08:24 PM
boat fan's Avatar
Rep: 357 Posts: 679
Hi Chris ,
No have not tried ......
Some debate on wharram long tails here ,
http://www.multihullforum.com/forum/...sp?FORUM_ID=36
http://www.multihullforum.com/forum/...?TOPIC_ID=2761
http://www.themultihull.com/wharram3...28/am1_156.jpg
Personally I would mount an outboard in a drop down pivoting pod.
Old 12-09-2008, 01:37 AM
Zaphod
Rep: 55 Posts: 45
Will check it out now still a way off but i like my ducks in a row.Thanks for the help.Regards Chris
Old 12-09-2008, 01:45 AM
Zaphod
Rep: 55 Posts: 45
and a genset not a bad idea.Im a a bit wary of outboards and the lack of flushing .oriental air coolel outboards available now????????who knows.
Old 12-09-2008, 02:36 AM
boat fan's Avatar
Rep: 357 Posts: 679
The new generation four strokes are very good these days Chris....
Old 12-09-2008, 03:04 AM
Zaphod
Rep: 55 Posts: 45
the oriental ones are air cooled diesel who knows about quality and relaiability
I like low revs with big props sorta old school thing that coupled with being a diesel mech off earth moving machinery.
Old 12-09-2008, 04:05 AM
Frosty's Avatar
Frosty Frosty is online now
Rep: 1528 Posts: 5,519
Drop down engine on a Wharram means that the engine is right where you dont want it. It has to be covered by an ugly box where you dont want it. Dificult to get coolant water to the engine. Noisy, smokey, bloody awfull.
Old 12-09-2008, 04:53 AM
Zaphod
Rep: 55 Posts: 45
The idea is good but it seems to cause a lot of problems its just that i want a good power source as well.A lot of hassle though.
Old 12-09-2008, 05:08 AM
boat fan's Avatar
Rep: 357 Posts: 679
Maybe a diesel / saildrive , or Shionning`s idea of vertically retracted outboards in wells. I hear what your`e saying about flushing them....and slow revs / big props....
Old 12-09-2008, 06:35 AM
Zaphod
Rep: 55 Posts: 45
a dilemma at the least.It makes sence to have a big diesel at 2200 rpm with a 15 inch prop. a 220 volt generator ,12v 200A charging,water pump, Raw water up and down the shaft all in one package .Ducted prop with rudder.
But ho to do it simply
Old 12-09-2008, 07:08 AM
Frosty's Avatar
thai boat plans needed..
I think there is something here for you
Old 12-09-2008, 07:51 AM
Zaphod
Rep: 55 Posts: 45
I surely hope there is.At least some light at the end of the tunnel ..Not a train please?
Old 12-09-2008, 08:37 AM
Zaphod
Rep: 55 Posts: 45
Hi Frosty.Raw water cooling but oh so simple.Perhaps the right way to mount it in a wharram on a pivot gets rid of the universal.use it for slow speed steering.Just put on a new sump and pickup.Auto disengage if the motor is pushed up.Not sure if there are any problems with a motor at 20 degrees.But its certainly worth some thought.
This is a wonderfull blog.Thanks Chris
Boomless Gaff "Wharram type soft wing" mark in nj Sailboats 5 11-20-2009 07:11 AM
need a catamaran navaleng Multihulls 7 12-10-2008 01:42 AM
Catamaran Devooo Boat Design 0 08-03-2006 06:15 PM
5 m Catamaran joaopereira Multihulls 1 04-18-2006 05:12 PM
Catamaran Tender for Catamaran b_rodwell Boat Design 4 02-18-2006 10:01 PM
