fpjeepy05
Sorry if there is a thread already covering this a couldn't find it.
Basically, I'm looking to do some reading about the scaling of designs. I'd like to know if there are some simple generalizations and equations that can be used for design development.
For Example, Proportionalities
If a boat is increased in length by say 20% assuming the boat takes the same shape beam, draft, and construction would increase by the same. So displacement might increase by say 1.2^3-1= 78%
But, as boats get larger or smaller people stay the same size so amenities might not change. For example there would be no reason for ceiling height, on the previous example, to increase by 20%
Also in the small boat range many boats get stuck on the 8'6" beam for trailering purposes so those may not increase.
Engines are a portion of weight and determine speed. As engines scale up max rpm traditionally goes down. (I understand this is a over generalization but a 50cc scooter engine can turn at 12,000 rpm and a Wartsila-Sulzer RTA96-C turns at 102 rpm) With this hp/weight ratio generally goes down, driving displacement up.
There is also the question of speed verses length. It may not be comfortable to travel the same speed in a boat that is 50% smaller and it may not be economical to travel the same speed in a boat that is 50% larger.
Can things be simplified? Or does everything have to be addressed individually for each design? Where do designers start? Designing for a HP, designing for a displacement, or designing for a length?
