Stephen Ditmore
- Joined
- Jun 12, 2001
- Messages
- 1,626
- Reaction score
- 77
- Location
- South Deerfield, MA, USA
The similitude table in Principles of Yacht Design by Larsson & Eliasson, first edition, Fig 2.1 (p. 12)(attributed to Barkla) caught my attention a while back. I thought this was a wonderful thing that I'd use at my first opportunity - but now that the time has come I think Larsson/Barkla have it wrong.
I'm scaling down a (historic -> replica) sailing ship, and it surprises me that Larsson has fairbody draft scaling with beam. It seems to me b/d is typically higher on small craft than on large, so while it makes sense to me that freeboard scales with beam, I'm thinking fairbody draft should scale (more or less) with length.
In the stability work I've done it's struck me that GM(req'd) varies very little, if at all, with size. A rather extensive discussion of stability formulae was posted earlier at:
http://www.boatdesign.net/forums/showthread.php?threadid=272
Since GM = BM + GB, the fact that GB will change as the vessel is scaled may mess this up some, but for the moment I'm going to assume that the center of gravity is close to the center of bouyancy, so that the change in GB can be ignored.
Since BM is proportional to I/Displ and "I" is proportional to LB^3, BM is proportional to (B^2)/d. I'm thinking that if d scales with L, then B ought to scale with the square root of the scale factor.
Let n=the scale factor. Since displacement = Cp*L*B*d, displacement would scale with Ln*dn*bn^0.5, therefore with n^2.5
(which is close to Larsson/Barkla's 2.4 exponent for scaling displacement).
Does this seem right? Are there other sources on similitude that would scale beam and fairbody draft separately, in a manner resembling what I'm suggesting?
So that this is not completely dry, here's an image of the historic H.M.S. Surprise, and a link to more information.
http://www.modelships.co.uk/Models/HMS_Surprise/hms_surprise.html
