| All this talk about Fiberglass cracks and core damage has me wondering, which type of construction requires the least maintenance? Fiberglass gets problems due to flexing. Eventually it cracks and water gets in the laminate. The USCG requires a 400% safty factor on hull loads , interesting that at 400% there is almost NO flex. An almost Zero maint boat can be created with Airex , by NOT reducing the skin scantlings for the foam. In other words if a 1/2 thick solid glass layup would be fine , splitting the laminate 1/4in outside , 3/4 Airex and 1/4 inch inside would not weigh much more than solid but WILL be about 300% TO 400% STIFFER. A boat built by hand over a plug (no female mold) will not have bonding hassels to the foam. A bit of workmanship on thru penitrations , as there installed , and you have a boat that can be ignored for decades. Franz Mass built many ocean racers with this technique , that are still out there sailing. Probably because a leak , stanchon base , whatever causes no problem for the Airex core . With no rot (ply core or balsa ) , and no water migration found in other core materials , many of the Lifeboat services prefer Airex for the unlimited service life , and ease of repair.Lifeboat service is ROUGH & Tough.! Surface finish is time consuming , but not expensive. FF |
| Well, it is a great title for a topic that interests me a lot these days. When would you use Airex and when would you rather use Corecell? |
| Thank you F F, I've built several very successful boats utilizing that philosophy. The biggest problems that we see in fiberglass boats today are #1 Poor quality product ( building materials) #2 Under trained labor and inadequate supervision #3 A lack of stiffness FAST FRED, I copied your above post along with the addition above to the composite boatbuilding section. I couldn't agree with you more. Building a Bruce Roberts Longboat 21 Gerald Last edited by Commuter Boats : 02-27-2009 at 02:02 PM. Reason: add link |
| yes I did Apex1, but now that it was alive again, I felt like asking more questions! ![]() |
While Airex is not a good choice for a deck it makes good hulls,klegecell divinicell etc are fine for decks,just stick with light colors. Steve. |
