I'll look into your recommendations. After checking out the company's website I did send an email to the regional distributor of the Armaflex AF and asked him for cost/availability information here in Alaska. I really do like the idea of wood core. I'll just have to see where this idea might take me. All of the issues like attaching any interior bulkheads, stringers, engine beds, interior panels, deck hardware, etc., are already clear in my mind when I imagine doing them with wood and epoxy versus in foam and fiberglass. When you build in wood core do you generally use solid wood strips or are you using plywood that is cut into strips as required to get the necessary bends? Regards, Roger |
we use solid wood for strips, then crossplank at least one layer of 3mm or 6mm veneer on the outside, befor glass / Ep is layed up. Depending on size of the boat and hullshape naturally. Have a look at my Gallery. I am NOT against foam in general, we did some nice boats in foam too, but went completely to Mahagony / Epoxy! We may change the species of wood once, or may use a different resin in future, but we´ll never go back to foam. Feel free to have your own thoughts about it. Another little dirty trick (if I´m allowed): have a laser level (a cheap one does) on your wishlist before you buy the first pot of resin. If a good Fairy has mercy, and you got it, apply and fix it on a tripod as if it is forever! Mark a line on (at least) two sidewalls of your "Boatyard", right angle if possible, or mark all walls, with a permanent marker. FINE LINE... Pump up your tripod and set another one at a higher level, you now have two "reference" lines to fix either your hull reference line (you´ll need that once a week), or your level again. Use the laser to make the centerline of your mould / frames setup. Once the centerline is fixed, move the laser beam upward to the ceiling, get a ladder and mark it there too! Every time you move you level, you´ll be happy to have some refence! Sounds silly, but there will come a day you´ll send me strawberries in winter, for that. Have succes Regards Richard |
Richard, I already have a laser level so I've got that one covered! I have a very nice 24' x 40' shop located right behind my house so I am set up nicely for a project of this size. I wish that I had built the shop with taller walls so I could build an even bigger boat. I only have 10' ceilings and a 9' door so that kind of limits my options. WHen I built my shop building I was planning primarily on using it for airplane and general woodworking projects, not a large and deeply hulled boat. I have in floor radiant heat, lots of light and AC power outlets, plenty of work benches, a bathroom, and a separate mechanical room so I don't have to listen to the noise of the large air compressor that pipes air throughout the shop. I probably should install some kind of a dust collection system to help with the dust that might be produced by a project like this. I also have an arc, tig, and a small wire feed welder, as well as a plasma cutter so I'm going to try to make as much of my own hardware as I can practically do. Roger |
| FAST FRED, said it well in the powerboat section...Airex and any foam based hull materials " #16 Yesterday, 03:15 AM FAST FRED Senior Member Join Date: Oct 2002 Rep: 263 Posts: 2,064 Location: Conn in summers , Ortona FL in winter , with big dock & room for O'nite stop . All this talk about Fiberglass cracks and core damage has me wondering, which type of construction requires the least maintenance? Fiberglass gets problems due to flexing. Eventually it cracks and water gets in the laminate. The USCG requires a 400% safty factor on hull loads , interesting that at 400% there is almost NO flex. An almost Zero maint boat can be created with Airex , by NOT reducing the skin scantlings for the foam. In other words if a 1/2 thick solid glass layup would be fine , splitting the laminate 1/4in outside , 3/4 Airex and 1/4 inch inside would not weigh much more than solid but WILL be about 300% TO 400% STIFFER. A boat built by hand over a plug (no female mold) will not have bonding hassels to the foam. A bit of workmanship on thru penitrations , as there installed , and you have a boat that can be ignored for decades. Franz Mass built many ocean racers with this technique , that are still out there sailing. Probably because a leak , stanchon base , whatever causes no problem for the Airex core . With no rot (ply core or balsa ) , and no water migration found in other core materials , many of the Lifeboat services prefer Airex for the unlimited service life , and ease of repair.Lifeboat service is ROUGH & Tough.! Surface finish is time consuming , but not expensive. FF" Thank you F F, I've built several very successful boats utilizing that philosophy. The biggest problems that we see in fiberglass boats today are #1 Poor quality product ( building materials) #2 Under trained labor and inadequate supervision #3 A lack of stiffness alaskarog, I'd like to avoid a debate on the merits of the various construction methods but completely agree with the philosophy that Fred has stated above and I have found that three quarters of an inch of foam on the topsides and one inch of foam on the cabin tops can go a long ways toward making a vessel more livable in our environment. Gerald Last edited by Commuter Boats : 02-27-2009 at 12:59 PM. Reason: add link |
| Bruce Roberts Lament | Wellydeckhand | Open Discussion: All Things Boats & Boating | 67 | 02-17-2011 05:31 PM |
| Bruce Roberts 53 | Guest | Boatbuilding | 3 | 04-22-2005 04:32 AM |
| Bruce Roberts Wavwerunner 55 | Patrick Smet | Metal Boat Building | 1 | 11-29-2004 07:10 PM |
| Bruce Roberts 38 | Redondo Beach | Sailboats | 0 | 11-20-2004 11:02 AM |
