Yvan Bougnon's circumnavigation in a beach cat project
Discussion in 'Multihulls' started by Corley, Jul 23, 2013.
  1. Manie B
    Likes: 123, Points: 63, Legacy Rep: 1818
    Manie B Senior Member
  2. El_Guero
    El_Guero Previous Member
    And I thought global warming was 'recent.'
  3. El_Guero
    I wish them fair winds and following seas.
    But, it seems they want this for the record books, am I right?
    Circumnavigations are supposed to round the southern hemisphere. Going through the panama canal requires powered (non wind) transportation as well.
    So, I am a little confused on this. It sounds more like a crossing of the 3 seas rather than a circumnavigation?
    Although I admit, a blown up kayak would be a challenge in the southern seas.
  4. Corley
    Likes: 199, Points: 63, Legacy Rep: 826
    Corley epoxy coated
  5. oldsailor7
    oldsailor7 Senior Member
    Quote:-
    It's disappointing that Nina for example didn't carry a proper automatically deploying epirb much of the waste of money in that case is tied to the fact the SAR teams could not determine an accurate area in which to search. New Zealand are prepared to take the economic benefit from having yachts stop in they cant divorce themselves from the responsibilities that are part of that including SAR when required.---- Quote.
    It can be done.
    During the 1969 New York/Bermuda multihull race, all the boats carried epirbs, provided on a loan basis by the company I worked for at the time, Garret Airesearch. LLC.
  6. Corley
    Corley epoxy coated
    Yvan and Vincent are making progress on their journey from La Corogne to Santa Cruz in the Canary Islands. They were beaten up initially by the weather but are now sailing in lighter trade wind conditions.
    http://defisma.com/calme-apres-tempete/
  7. SamSam
    SamSam Senior Member
    How much time is this expected to take?
  8. Corley
    Corley epoxy coated
    A long time, it could take a year or more for the circumnavigation the boat is not particularly fast.
  9. sharpii2
    sharpii2 Senior Member
    Not surprising due to it's probable weight.
    Multis are only fast when their weight is kept down.
    Hard to do that with a lot of cruising gear on a boat of limited Length.
    A Mono of the same length and weight would probably be nearly as fast and, even without ballast, probably safer and more comfortable.
    The stores could be stowed in such a way as to act as self righting ballast, or go a long ways toward that. But a mono of that Length completing such a voyage would be hardly worth any print.
    Of course a multi, cat or tri, with fatter hulls could keep the wing deck at a more reasonable height above the sea and even allow for higher speeds, as there would be less whetted area exposed to the sea (the wing deck)
    But if that were done, the sailors would certainly inhabit the hull(s), spoiling the record attempt.
    I think this record stuff is getting a bit silly.
    Are we just glorifying people's ability to endure needless suffering?
    100 strokes per once of fresh water? Man that's a lot of work.
  10. buzzman
    Likes: 25, Points: 18, Legacy Rep: 99
    buzzman Senior Member
    A circumnavigation ...is a circumnavigation.......whether you go "via Panama" or around the "three Capes" in the high latitudes.
    Of course, if their attempt at the middle passage is successful, how long will it before before someone even crazier decides to attempt the three Capes route?
    Personally, I'd rather have a storm cover over the wing pod, at least, so you could get dry and sleep, as both of these seem to have been the MAJOR problems for all other trips by open cat.
    Both Pradel and Laurent suffered severe sunburn and sea sores because they were unable to get dry at all, Daniel even required skin grafts, and both stated that sleep was well nigh impossible until they were so exhausted they simply fell asleep where they sat - but that type of sleep, especially when interrupted, does not properly rest the body.
    But good luck to the "mad Frenchies" anyway - it's certainly a major effort, although it looks like they are coast hugging down the African coast, rather than taking the straight run offshore to the Azores.
    Typically, the website has no translation.....bloody Frogs..!! ;)
  11. SamSam
    Has anyone ever done a North-South circumnavigation?
  12. buzzman
    Bit problematic, with the continent of Antarctica in the way..!!
    Closest so far is probably Matt Rutherfords circumnavigation of the Americas via North West Passage and Cape Horn
    http://www.solotheamericas.org/
  13. SamSam
    It looks to be more direct than all the dodging around the Americas and Africa in an E/W track, but that would more or less be the course, down the Pacific and up the Atlantic or vice versa.
  14. El_Guero
    That is a nice looking beach cat ....
  15. Sleepingsadhu
    Sleepingsadhu Junior Member
    Best of luck to these folks, any live tracking?
