The latest update from Yvan, pretty miserable by the sounds of things.
https://www.facebook.com/ybourgnon/posts/1633776726641711
Frozen drizzle by 71° North on the défi challenge
The problems of the last 36 hours are still topical. As in a bad scenario, yvan bourgnon doesn't see the end of the rain. Of course, the fellow has seen others, but tropical trombes are lukewarm and dry.
Here the water from the sky penetrates you to the bones, after infiltrating layer after layer through the very technical clothing. And to add to the torment, yvan is obliged to stay under this icy flood to steer, because solar panels are ineffective because of lack of brightness.
4 layers of wet clothes, 4 layers of gloves filled with water, the down where yvan tried to warm up for an hour, soaking wet!
However, about ten hours earlier, a truce he hoped was lasting for 3 hours. Time to change completely, to eat under normal conditions, to recharge the batteries in a little less grey.
Barely time to wonder if it would hold, that the rain was already back! " 4°, a fine and icy rain, 20 hours a day I hope it's Alaska that's like this! It's steep! I didn't make a good choice of gloves, I should have prioriser the seal. I only have one down and it's soaked, no chance to dry anything for now. Holy Cow! I can't imagine what it would give with wind! ' cause this is quiet, I'm moving 3-4 knots but am in the fog, visibility is not good."
Search for a solution
For a little comfort, yvan could get closer to a bay to get wet and enjoy the coastal temperature that can climb up to 15° in the afternoon. " but well, I could just sleep more easily, for the rest if the rain is still there, it won't do me any good."
In addition, a stop would delay the arrival of yvan in the vicinity of point barrow, or a fine coastal strip of 2 miles wide free of ice could pass. " the wind needs to be strengthened on 21 and 22 July, possibly up to 30 knots. I'd rather pass barrow and the goulet on the edge of the ice before."
If Yvan takes his patience and manages to plunge into the free water corridor on the edge of ice, he will have to be extremely vigilant, between drifting ice and rocks from the nearby coast. Over the next 70 miles, he would have to stay within 5 miles of the coast to make progress.
This litany sounds like a blues, Alaska blues by 71 degrees north. But it would take little to make yvan happy: "let the rain stop, the sun appears and everything will be in order".
