Yrvind
Discussion in 'All Things Boats & Boating' started by Manie B, Aug 16, 2011.
  1. Manie B
    Likes: 123, Points: 63, Legacy Rep: 1818
    Manie B Senior Member
    oh well so it goes
  2. Manie B
    the point I am making here
    (and please believe me I am trying to learn as much as possible from everybody, my own life will be on the line soon)
    nobody but nobody can succeed after one day sea test
    Sven's years and years of experience carried him thru, if it was anybody else they would not make it.
    he is obviously good at catching rain water
  3. Manie B
    Thank you
    Angel and Yes
    and to all the fellow BD.net supporters on this thread
    it was very nice to have your interest and support on this very interesting journey
    we all learn a little every day along the way
    I am almost finished the outside
    cant wait to get back inside the boat :D
      File size:
      233.2 KB
  4. Angélique
    Thank you Manie for starting the thread and for your input [​IMG]
    I think this thread can carry on to discuss the news about Sven as it comes in . . . .
    And good luck with the build and the and the subsequent journey . . :)
    Cheers,
    Angel
  5. Angélique
  6. Yes
    Likes: 5, Points: 3, Legacy Rep: 19
    Yes Junior Member
    What she said
    Cheers,
    Yes
  7. Angélique
    Sven keeps us updated....
    New courage ---> New plan ---> Martinique . . . . . . and some info about the problems with the boat . . . .
    See.. Present project uppermost for now, or archives September 11, 2011.
    Cheers,
    Angel
  8. Angélique
    September 11, 2011
    Sven seems to have discovered that between june 1 and july 2, 2011 and tried to solve it with a mizzen . . . ?
    (but I'm not sure if the mizzen was planned or not)
    June 1, 2011 no mizzen
    click to enlarge
    (the big thing with the flag is the rudder in upward positon)
    July 2, 2011 with mizzen
    click to enlarge
    See about the skipped bowboard....
    - October 7, 2008 - RUDDER & BOWBOARD - (bottom post)
    - June 14, 2009 - ON THE IMPORTANCE OF BOWBOARDS
    - December 1, 2009 - THREE STEPS BACK AND A NEW THEORY FORWARD - (bottom post)
    What are Sven's options now to improve the leehelm, what's your advice . . . ? ?
    Cheers,
    Angel
  9. Tad
    Tad Boat Designer
    Changing the trim or raking the rudder forward might help a bit, but I believe the best solution (at this point) is a dagger board. Outside the hull, in clips on the topsides, four clips and one board, probably just aft of the main mast.......or perhaps grind away the chine runners aft? Experimenting (something Yrvind loves) is the answer.........
  10. Manie B
    absolutely
    and Angel you are right, he has experimented with it all already, time to go "conventional"
  11. Manie B
    The real (sad) truth is that nobody can do sea trials in one day and set a boat up properly for a long distance voyaging.
    Any experimental boat like this needs a LOT of time to get going properly.
    I am no hero and I have serious technical backup
    http://5psi.net/ and http://www.epsilon-eng.com/
    but this boat of Sven needed more input from a NA or the engineering type
    AND it would not have detracted from his own individuality or "personal" touch. It is obvious that the CE - LCR - LCB calculations are not their strong abiliities.
    But "sigh" the smallest this and the smallest that is what attracts us to these colourfull people with their unbelievable thirst for adventure. I absolutely love it, but I am a sissy that is fanatical about safety at sea.
  12. Manie B
  13. Angélique
    Maybe within the current construction it's possible to swing the rudder a bit more forward then perpendicular..
    Well, I assume he still has the now obsolete bowboard, but not sure it's long enough to fit outside... maybe better make a longer one..
    December 20, 2008 - - - - - - - - - - - - - - - - - - - - - - - - December 1, 2009 - (bottom post)
    [​IMG] - [​IMG]
    - - - - - - - - - - - - - - - - - - - - - - - - - - - - - (click pics to enlarge)
    and/or extend them forward . . ? ?
    I think you're right :), and thanks for the reply [​IMG]
    Cheers,
    Angel
  14. Manie B
    Angel I love your posts
    because it is making this thing look like a hit and miss affair too much ;)
  15. GTO
    Likes: 9, Points: 18, Legacy Rep: 101
    GTO Senior Member
    It does look that way. There seems to be only two ways the chine runners can work: thru a high drag vortex or creating a wing-like effect with the bottom of the boat as Matt Layden suggests. So I guess it's possible Yrvind simply got the bottom/runner design wrong. However, the whole concept flies in the face of the conventional wisdom that shallow keels will lose some if not most of their effectiveness once the water gets rough (see A Voyage for Madmen, Peter Nichols, for one description). So at the worst possible time, the chine runners lose effectiveness and the rudder becomes the primary keel.
    It will be interesting to see if the design can be make to work comparably to a conventional keel, or at least well enough for the shallow draft benefit to out-weigh the windward disadvantage.
