Yrvind
Discussion in 'All Things Boats & Boating' started by Manie B, Aug 16, 2011.
  1. Westel
    Likes: 4, Points: 18, Legacy Rep: 43
    Westel Senior Member
    Angel,
    the outside contour of that box only needs to be 2 or 3 centimeters wide and no higher than the anchor itself. If he makes a lightweight cover for that box in the same material as his hull, he can easyli sit on that or stand on it.
    Just and idea....probably a useless one..:D
  2. Angélique
    As said, the cost of a few cm of interior space was the only downside I could think of, and it was just a little one that was inspired by the idea that Sven is fiddling with every cm inside the boat. In my previous post I acknowledged not to drive screws into the hull as an advantage of the box. The above mentioned capabilities to sit or stand on the box are also advantages, as is that it's less harmful to fall on a box than on bare anchors. Overall I think the Divinycell anchor box would be an improvement, worth the few cm interior space it takes.
    - - Ex Lex forepeak - -
    - - click pic for source - -
  3. Angélique
    Re the end of post #509:
    [​IMG] PUR Survivor 35 desalinator - - (Note: PUR is the old name of Katadyn)
    When start at 0:44 and you only miss the jetty walk and some music, at 3:09 I saw some leakage from the pressure indicator.
    Below a lady gives a ‘‘dry demonstration’’ of the smaller Katadyn Survivor 06
    [​IMG] Survival at Sea: Reverse Osmosis Pump
  4. Angélique
    There's a lot of great updates of Sven's building progress [​IMG]
  5. Angélique
    My guess is they counted the age of mind . . . . :)
    Congratulations to Thomas and his Bride . . . :cool:
  6. Angélique
  7. Angélique
  8. GTO
    Likes: 9, Points: 18, Legacy Rep: 101
    GTO Senior Member
    water contamination
    I've read Sven's idea of using his breath to pump water out of his larger containers into smaller bottles and wonder if this might contaminate his water supply.
    It seems like room temperature water and bacteria from his mouth might lead to nasty growth in the tanks.
    Anyone else have an opinion on this?
  9. Westel
    Something I certainly would try-out before putting it in use, smoker or non-smoker lungs...:D:D It's not the air from the lungs that might contaminate but what the airstream picks-up, passing through the mouth into the cannister.
    On the other hand, 50 years ago we used to go swimm in canals, shared a cola with 3 kids never washed our hands when we ate candy and sometimes even chewing gumm changed mouths.....:eek:
  10. Manie B
    Likes: 123, Points: 63, Legacy Rep: 1818
    Manie B Senior Member
    this is a family orientated website so I wont say too much ;);););)
    50 years ago I was 13 and swopped gum with a girlfriend
    and learned a wicked thing called "French kissing" and the rest is history :p
    we were soooooo innocent compared to todays kids
    so I would not worry too much about Sven blowing into his water bottles
    he'll be ok :cool:
  11. Manie B
    Sven this is very interesting
    :D now I know where you are going
    :D excellent
    please come to me in Houtbay my "ten" will be there from February to September next year
    fair winds - take care :)
  12. Angélique
    At least Grandfather survived it and was able to tell about his experience. So if it was the last water I would take his advice and drink it rather than die of dehydration. By storing it for the last hopefully gives it time to rot the required three times, and the need to use it could be canceled in that time by not needing it because of new supplies of rainwater or maybe landfall.
    Sven you have devoted readers, appendicitis is a wrong example in your case, but indeed another acute medical necessity could force to landfall and it's a good thing to be prepared for it and share the precautions with your fans . . . :cool:
  13. Angélique
    Just noticed Sven's website is offline at the moment, so above links don't work for now, hope Sven is OK and the website troubles are only temporary, and we can read soon from Sven again.
    P.S. - Sven's website is back online now . . . :)
  14. Manie B
    :D
    Sven you read my mind
    That is definitely what I am going to do :)
    Many thanks for your advice
    always greatly appreciated :)
  15. Manie B
    Message for Sven,
    Hello Sven,
    In which town or city are you?
    My partner Anthony now works in Stockholm.
    He would love to come and meet you.
    He will phone before the time and make an appointment.
    Regards
    Manie
