tropostudio
Senior Member
- Joined
- Dec 17, 2014
- Posts
- 222
- Reaction score
- 83
- Location
- St. Paul, MN, USA
A boat 7m long that makes ~10km/hr or 6.2 mph, with or without foils attached. Was the boat foil-borne with them attached? You didn't mention it.
You are analyzing 2D foils at Re at Re 100,000. So that means you are using a foil chord on order of 2-3 cm? This sure sounds like a project to foil a low speed, human powered boat.
Your 3D printed foils are breaking, so you may switch to a cambered plate steel foil. We have no idea what the finish is on the printed foil.
Are you juggling too many variables here? The qualities of strength and finish for similar craft - say kite foilboards - is what you should be aiming for. You can't make informed comparisons amongst foils, in practice, without getting your fabrication and structures sorted out. I'd venture that if you can do that, correlating results to software will be a lot more meaningful. You'll at least have some evidence to back up assumptions. Don't mean to be rude - just practical.
