tom kane
Senior Member
- Joined
- Nov 1, 2003
- Messages
- 1,768
- Reaction score
- 51
- Location
- Hamilton.New Zealand.
From the very first install of power boat shaft drives they have never been installed mechanically correct but just for tradition and appearances.
Centre line motor crank and prop shaft drive is incorrect.
Using twin u/v`s install the motor should be off set in relation to the u?v`s and off set in relation to the shaft down angle for longer service and less maintenance and vibration.
The prop shaft should be off set of the centre line that side determined by the prop rotation.
Rudders should be also off set from the centre line of the shaft for optimum steering and control of torque and better steering.
Would you sacrifice symmetry, tradition, appearance for longer reliable service with less maintenance, less vibration and a more balance control?
It`s all about good boat design.
