Would this work? (cutting a 15' fiberglass canoe in half to make a stable dinghy)
Discussion in 'Projects & Proposals' started by SpiritWolf15x, Nov 2, 2012.
  1. SpiritWolf15x
    Likes: 1, Points: 18, Legacy Rep: 15
    SpiritWolf15x Senior Member
    Would cutting a 15' fiberglass canoe in half at the widest point and glassing a 1/2" plywood transom into it make a stable, usable 7.5foot dinghy or would it just sink?
    I'm not planing on doing this with my existing canoe, I'm just curious... =P
  2. Ike
    Likes: 511, Points: 113, Legacy Rep: 1669
    Ike Senior Member
    It would probably float, but it sure wouldn't carry much of load, I doubt even an adult.
  3. alan white
    alan white Senior Member
    The canoe's carrying capacity would be divided in half. It would be better to remove both bow and stern, maybe 3 1/2 ft each. Then it would carry an adult with no problem. If the transoms were angled (bow maybe 30 degrees, stern 10-15 degrees), it would row okay or even motor--- however slowly.
  4. parkland
    parkland Senior Member
    It works decent, guys do it for hunting quite often here.
  5. nukisen
    Likes: 8, Points: 0, Legacy Rep: 124
    nukisen Senior Member
    Why not cut it in the middle longitudinal and place the sheet in the cutted area.
    Then you are able to use it as a catamaran. :)
  6. SpiritWolf15x
    I might end up doing just that. As it is just sitting in my yard now.
  7. gonzo
    Likes: 2,262, Points: 123, Legacy Rep: 2031
    If you could cut it at 9' it would be much better.
  8. nukisen
    Else you can cut it just in half. Glue a pair of boot in the bottom and use it for walking on water as Jesus. :D
    Anyway you have good oportunity to have fun as a creative person. I bet you will have som fun with it. :)
  9. nukisen
    Spiritwolf!
    Did you make any fun out of your canoe?
    Would be fun to know.
  10. SpiritWolf15x
    Nah, it's sitting at the side of my house being ignored, I ended up finding a steal of a deal on a 8' fiberglass lapstrake rowing dinghy so I just went with that.
  11. parkland
    Nice boat !
  12. SpiritWolf15x
    Yeah it's not a bad find for 350$
  13. wayne nicol
    Likes: 11, Points: 18, Legacy Rep: 34
    wayne nicol Senior Member
    cut the canoe in half, a transom for each half, bolt them together, use as a long canoe- or two shorties when needed.
