Worst Yacht Design Ever?
Discussion in 'Boat Design' started by intrepid71, May 15, 2016.
  1. intrepid71
    Likes: 4, Points: 0, Legacy Rep: 39
    intrepid71 Junior Member
  2. PAR
    Really? Don't you think a 500' vessel has sufficient enough mass, to hold up that stateroom?
  3. intrepid71
    A stateroom? Maybe. A swimming pool? No.
    Maybe it has a 80 ft lead keel.
    I also like how there appears to be no way to have an elevator going up to that cantilevered 135' ft high deck. They will need to find a billionaire who likes climbing stairs. Either that or install an escalator.
  4. rasorinc
    rasorinc Senior Member
    I would like to see the elevator to that stateroom.
  5. BertKu
    Likes: 45, Points: 58, Legacy Rep: 223
    BertKu Senior Member
    The designer, not to confuse his guests, probably has on the left an escalator going up and on the other side an escalator going down. Bert
  6. boatenthusiast
    boatenthusiast Junior Member
    the desighn itself does not look unstable to me, that is all i can add to this thread.
  7. Stumble
    Stumble Senior Member
    The designer actually is a yacht designer who works at a reputable design firm. So I assume that were it to be built the engineering to keep the boat stable would be done professionally as well...
    It still looks stupid, but I don't think it's unbuildable.
  8. serow
    Likes: 3, Points: 8, Legacy Rep: 40
    serow Junior Member
    It's wide at the stern so unsurprisingly they've drawn something that is build-able rather than have to backtrack when someone makes a serious inquiry.
  9. intrepid71
    It wouldn't be the first ship to be built that capsized soon after.
    I'd love to see what happens with that upper deck pool if the vessel was in a seaway.
  10. gonzo
    Deck pools are either drained or covered when underway. That is a solved problem; there are thousands of onboard pools.
  11. PAR
    Water doesn't weigh all that much, Intrepid, why would you think this would be unstable?
  12. Mr Efficiency
    Why would anyone care ! "Omnipotent" seems like a name guaranteed to attract bad luck .
  13. pogo
    pogo ingenious dilletante
    Yepp.
    It's styling, it's fashion, something new.....
    The yacht looks good.
    Exaggeration in styling pretty often shows the things to ( be) come in " design".
    Look at this established "design":
    No sidedeck , no clamps, massive aft platforrm, negative angled ( rebell- sharp looking) targa , slippery foredeck with very low fence but bunny - pad, very high freebord.
    An overpowered , sharpened max. volume container.
    http://photos.croatiacharter.com/four-winns-258-vista-1743_2bcc.jpg
    America.
    pogo
  14. Rurudyne
    Rurudyne Senior Member
    Humorous: I'd worry about the stability of the buyer. ;)
    I'm sure it'll be made out of lots of carbon fiber.
    I'd be worried about motion sickness.
    Up that high the motions will not be small.
    Heaven help folks if they use powerful gyroscopes and end up with motions that are also quick.
    That said, all that weight up high might help make things be nice on the (much) lower decks.
  15. JSL
    Likes: 61, Points: 28, Legacy Rep: 41
    JSL Senior Member
    I don't think stability is an issue:
    Boat heels = [pool water spills out + (people fall + all loose items) fall off)] = stability improves --> boat returns to an upright condition.
    What could be a problem is any roll effect will be magnified several times making habitation uncomfortable. On the upside, this mariner's trebuchet should keep everyone in good shape.
