Wooden dory/skiff
exmoore
New Member
Joined
Dec 27, 2016
Messages
Reaction score
Location
Virginia
Picked up a wooden boat (covered with fiberglass on outside) that was built here in Virginia Beach in the '60s. It is about 18 feet long, narrow, good shape - wood is solid. Need some fiberglass work. Stern is angled sharply - for laying out nets I am told. Anyhow, it has a hole in the deck where an outboard motor used to be - through the hull. I am told outboard motors were placed through the hull so nets could be layed out without the motor being in the way. I had intended to cover the hole and have a bracket built to hang a motor off the transom, but I think I want to keep it original. I am trying to find information as to how to build a bracket/box to hang a motor through the hull. One of my issues is that I don't know what that configuration is called so everything I Google is not what I am looking for. Any information or links to any information regarding this type of set up would be greatly appreciated.
Erik
li7PnKhAUotK9EfrB5m_EcT21-iQ69isng5d3FMaFFZsPDvYXFgHrqXoM_N7rkOgr0pkkmd_wcZJb8M=w1366-h589-rw
Hi Erik,
Welcome to the forum . . :)
Google: - And also try Google Images:
outboard well - - | - - outboard motor well
outboard well plans - - | - - outboard motor well plans
outboard well construction - - | - - outboard motor well construction
outboard well design - - | - - outboard motor well design
outboard well dory - - | - - outboard motor well dory
outboard well skiff- - | - - outboard motor well skiff​
Good luck !
Your outboard hole is near the transom, so if you want the motor to be able to tilt you could close the fore end of the hole and move the hole a bit aft so you could build the well like it is on the Simmons Sea Skiff, see this ad and below...
The same outboard well construction can be seen below on the Seaman Sarah Ann and the like...
Welcome to the forum.
This is called a well mounted outboard installation and it's more common than you might realize. The examples shown above are one approuch. Another approuch is to have the engine mounted a little (or a lot, as in some fishing skiffs) farther forward. In both cases, the engine is bolted to a false transom inside the boat and a box is placed around it, to prevent the water from climbing aboard your boat. Often a lid is used to keep noise down.
In low power applications the transom can just stand up with some minor bracing (knees, etc.), but once the outboard size gets over say about 15 HP, you'll likely need some athwart bracing, to prevent wracking. The box does need to be well thought out, to prevent leaks and provide sufficient stiffness. Transom heights, aperture size and location, ventilation, etc. all are things to work through as you develop the design.
Post some photos of the boat, so we can see what you're working with.
Thanks for the suggestions and info Now that I know what it is called, it is easy to find information. I may have to rethink what I am planning to do.
Erik
Hi Erik,
See PAR's website for suggestions and info how to put it together:
- ---> Epoxy Tips & Tricks ---> Liquid Joinery ---> Structural Fillet Anatomy ---> Fillet Types ---> Click the Pics
Go for the Heavy Structural Fillet type there for putting the box together and to join it to the boat . . :cool:
Best ask PAR for advice how to do the right angled outside corners of the box . . :idea: - (as I don't see a suggestion for this on the linked pages)
Good luck !
Outside corners are simply rounded over sufficient enough radius to permit the fabric or tape to lay down neatly. A 1/4" (6mm) radius can work, but will prove problematic. I consider a 3/8" (10mm) radius a minimum round over for fabric to lay down without puckers and the like. The 3/8" radius also is easier to make look nice too.
In the end, your repair approuch needs to take the boat's original construction into consideration. If it's as you've described (solid wood, not plywood) you will likely not use much epoxy, compaired to fasteners.
Angélique, this image is on my site and does show an outside corner treatment. An ideal fillet should have at least the material thickness in goo, at it's deepest portion. The 3:1 rule I use generally insures this will occur, depending on how obtuse the joint becomes.
Thanks for the reply PAR
P.S. - Erik, the post #1 picture is gone :confused: - Could you repost it please :?:
