If you don't design the shape of the boat and its volume distribution, appropriately for the anticipated scantlings, how will you know if it'll float the way you want, such as right side up or at the LWL you envision? Spira's dories are designed around a specific set of weights and their respective locations. As a powerboat, they're less than desireable in terms of efficiency, comfort underway and build materials, but yeah, you're the designer/builder. It's just as easy to build a boat that will not meet any of your expectations, as it is one that does. You can guess and hope or take a more refined course, it's only money and time, right.
If you're going to use PL as the adhesive, you'll spend more than using epoxy, ounce per ounce. Epoxy is superior in every regard, particularly dynamic loading, which boats are highly subjected to. PL is s static load adhesive with a very poor modulus of elongation attribute. PL works great to keep paneling on the walls of your family room or to keep plywood from squeaking over the floor joists, but ask it to accept dynamic loading and it'll fail, because of this elongation modulus weakness.
Lastly, there no sense in using epoxy, unless you're going to encapsulate all the wood, not just places you think you should. The only advantage to its use as a coating, is to stabilize moisture content. Unless the pieces (all of them) are completely coated, including screw holes, cutouts, etc. you just slathering on really costly goo that's not going to prevent moisture gain.
Given the costs of the Spria plans and others in this general size range, what's the point of the "hunt and peck" approach to the design? You'll spend more on a single coat of paint on this puppy, compared to the plans, so is the budget this tight, you need to peel off a hundred bucks? If this is the case, you're going to cry, when the cost of lots of other stuff hits the fan. The last place you want to cut a corner is in the plans.
