Wood Preservative, Copper Naphthenate
Discussion in 'Wooden Boat Building and Restoration' started by randy@poles.com, Sep 23, 2015.
  1. randy@poles.com
    randy@poles.com New Member
    I'm new to your site.
    I get calls from wooden boat owners that purchase 2% Copper Naphthenate wood preservative from us. They usually use it on hull restorations. It has an odor, and you don't want to get it in the water. Copper Naphthenate has been used for close to 100 years as a boat wood preservative. Has anyone used this preservative lately? Do you have questions for me?
  2. messabout
    Likes: 572, Points: 113, Legacy Rep: 1279
    messabout Senior Member
    I have used it way back in time. I was unaware that you can still buy copper naphthenate what with EP regulations and all.
    There are different ways to preserve boat wood these days, epoxy saturation for example.
  3. PAR
    Likes: 505, Points: 93, Legacy Rep: 3967
    Why would we have questions for a poster after his one and only thread, which offered nothing new in it?
  4. Petros
    Petros Senior Member
    I have used it on outdoor wood projects like decks and stairs around my house. it is sold in small quantities for use as an "end cut" solution where you cut pressure treated lumber. I have also applied it to landscaping timbers to try and make them last a bit longer. Not sure if that worked, eventually even the treated lumber breaks down when in contact with the wet ground.
  5. SamSam
    Likes: 200, Points: 63, Legacy Rep: 971
    SamSam Senior Member
    what is the odor from and can it be eliminated?
  6. PAR
    Carboxylic acids are the big culprit and nope, not even a full up respirator can get rid of the smell completely.
  7. Lepke
    Likes: 6, Points: 8, Legacy Rep: 10
    Lepke Junior Member
    Before the EPA we had good wood preservers. Cuprinol back then was widely used. Treated wood didn't rot or get soft. The current Cuprinol is different. There was another preservative made in the boatyards that consisted of some form of copper and arsenic. It was water based and in 2 parts. It worked best with damp wood. I don't remember the formula. Wish I did.
    Now with the EPA we have to cut down more trees to replace rotted wood that could still be good. Commercial operaters are scraping good diesels and the diesel fuel we get is crap. It doesn't burn well, causes diesel stoves to soot up and I have to add a catalyst to diesel in the winter so my truck will start.
  1. sdowney717
  2. sdowney717
  3. IwoodifIcould
  4. sdowney717
  5. CDBarry
  6. skaraborgcraft
  7. Rod Tait
  8. Brian Fredrik
  9. Person named james
  10. Samdaman
