I messed up my excell drawing that time. Most time it is better.
You could use other than H80. Depends on the design (spacing of ribs). Can even be a light foam core, no ribs. Just relying on biax layers and unis. The core takes up the compression stress.
For a nodeless (no rib design, tapered, differing cross section), lay up can be 90/0/+45-45 with the uni 0 degree taking up most of the bulk. The ratio is about 15% biax on the outside to take care of shear, 70% 0 degree uni for bending strength, and 15% 90 degree fibers to prevent collapse/buckling. This is filament winding method.
Carbon uni is a necessary evil if you want bending strength approaching that of alloy. Eglass can be used for the 90 and +45-45 degree. The author cautions about using Eglass uni with +45-45 because of differing strain. Apparently the +45-45 Eglass has low strain compared to Eglass Uni. I haven't found any reliable data yet to confirm. Anyway, design is always a compromise. Bulk of 1 direction can be increased, thus Eglass uni can be used. For comparison, Carbon uni and certain species of wood has similar strain.
I need to look into this with more details to see what I can change and leave the same strength as the original. I would leave the ribs and stringers as necessary, if I can switch on most parts (ribs, ply, etc) from wood to divinycell is already a big improvement on my view (no rot).
The good point is that I have one reference to compare to.
