Wood/epoxy composite moisture movement
It seems like a strange trade off still as the expansion of the wood ruins the part regardless of what fabric you use, Just my Opinion
It will only contract and expand significantly with moisture. Temperature will not affect it much. If the wood is encapsulated, thin or thick laminations make no difference. The species is not important either. Rot resistance is important for traditional construction that is only painted or let bare.
In another thread, PAR (of legend) also suggested these properties of Xynole fabric, though whether he got this data from rigorous testing, sale brochures, or his own experience, I don't know.
I'll make it easy, polyester fibers have a high elongation at break, something in the order of 40-60% depending on the exact fiber. Standard boatbuilding epoxies have an elongation at break of around 5%. Something like G-Flex has 32% elongation, and there are some special epoxies that go even higher. In order to realize the benfits of flexibility you need to at least match the resins elongation to the reinforcement, ideally you want more so that the reinforcement takes all the load and the epoxy remains unfractured thereby maintaining the waterproofing film even if the fibers break.
In reality wood won't move unless it significantly changes moisture content. That's why everyone uses the magic word "encapsulation" that's having epoxy on the entire surface, not only on one side. In order to inhibit the moisture transfer you need to maintain the integrity of the coating. In areas that don't suffer from mechanical intervention a thin coating of epoxy is enough. When it comes to mechanical action you need a thick strong layer. Yes xynole fibers resist abrasion better, but it's inconsequential to waterproofing, the resin will crack long before the fibers give up. Of course xynole uses much more epoxy, so if you want to compare apples to apples you have to use a fiberglass thickness of similar weight per surface area.
But, ultimately it's really simple, on a wood epoxy boat if you see a ding in the paint you start repairing it. If you have areas where you expect frequent mechanical wear you add significant material thickness to soak it up before it reaches the primary wood coating (like for example a skid plate). What you use for it is ultimately a matter of preference there's silicon carbide doped epoxy, there's kevlar felt, polypropylene fibers, etc.
Thats exactly what i mean. The resin will snap long before the fibre does. Epoxy, e glass would be around the same so why would anyone choose to use this polyester fabric instead of e glass in this specific context of trying to roll with the expansion rate of the wood
How do you encapsulate the wood. What do you mean. Is this the sheathing of soaking it in resin or something
I'm sure he just means an appropriately thick coating on all sides so the piece is totally sealed.
long time ago (late 70s):
sheathed my 34' Wharram with Epoxi + 200grm Polyester cloth, did some preliminary tests, also comparing with glass/epoxi:
bond between PE cloth & Epoxi is weaker than glass & Epoxi, which, in this application is beneficial: PE cloth distributes impact more & stays "unbroken" longer, as it pulls away from the ply a bit before breaking. Glass adheres stronger=breakage of sheathing.
as to "thick timbers" vs. laminated: always go for laminated in wood/Epoxi construction. The more laminations the better.
Best literature: Gougeon brothers on wooden boat construction
I've been reading some books on cold molded construction and came across some possibly conflicting information that I'd like to discuss here.
Reuel Parker advocates for the use of larger, single timbers vs laminations in structures such as the stem, horn timber, etc as the construction is more efficient and cost effective. He suggests polyester or Xnole sheathing to cover any exterior wood as this material is much more flexible than glass.
In Sam Devlin's book on the same topic, he argues that, even if sealed in epoxy, any dimensional lumber significantly larger than 1/2" can swell and overcome the elasticity of the epoxy, resulting in cracks and failures. When considering ac service repair, the same general idea of addressing the underlying cause rather than just covering the symptoms comes to mind. He advocates solely for laminations of plywood for any members larger than 1/2".
Perhaps this has been discussed here before, but do you agree or disagree with either of these arguments? While I tend to agree with Devlin's statements (water is insidious), Parker's advice seems practical. What are your thoughts/experience?
I think Devlin’s argument is the safer one for critical structural members. Epoxy can seal wood, but it doesn’t eliminate dimensional movement, especially in a large solid timber. Repeated moisture changes can eventually put enough stress on the epoxy coating or surrounding joints to cause problems. That said, Parker’s approach can work if the timber is properly dried, selected, sealed, and protected from moisture. I wouldn’t say large solid timbers are inherently unsuitable. For something like a stem or horn timber where long-term stability is important, I’d personally choose well-made laminations when practical. You get better control over movement and can also distribute defects through the member. Solid timber can be perfectly serviceable, but it demands more attention to moisture and construction details.
Yes. There are many ways of encapsulating wood. Some are more durable than others. Thickened epoxy works well, but is not as durable as laminating with epoxy/fiberglass. Alkyd paint is adequate for above the waterline or interior areas. You need to first determine the application and the species of wood.
