Wondering about some improvements
Discussion in 'Powerboats' started by Geno67, Jan 29, 2026.
  1. Geno67
    Likes: 35, Points: 18
    Geno67 Clueless Member
    I recently acquired a fully reconditioned 1992 Grumman Fun Ship 18' pontoon with a 1996 2 smoker Johnson 115 SPL. It's mission is hunting/fishing and does a pretty good job. It does sit low in the rear as all of the old 2 log pontoons with a big(ish) engine do.
    Top speed is 30 and I would like to do a couple of things with some sealed sheathed ply pontoons. Increase the flotation to sit higher in the rear, increase efficiency/top speed/cruise speed with flat bottoms that are wider than the round logs (currently 25" round). It's all bolted together so it would just be a matter of unbolting the old ones and bolting new ones on once they're constructed.
    I'm thinking 1/4" exterior ply for bottoms and sides. 3/8" for flat tops that will be 6" wider than the sides allowing for 3/8" stainless steel through bolts on each side at the cross members which are at 16" spacing. 6" glass tabs, 12 oz biax sheathing with epoxy. 3/8" frames every 36" or so.
    Thoughts on shape/size to get the most speed out of it? I'm looking for light weight of course and additional buoyancy.
    594574654_704259349433863_8991994675840658738_n.jpg 595112425_690537187254159_802168357693058563_n.jpg 595120191_1485656789161291_1131130633835488002_n.jpg 595189180_1485399913154252_7880634669517792285_n.jpg 595213361_733426759808030_6489642995401767683_n.jpg 595274787_2070316733788533_6335540657786052004_n.jpg 596773101_1134358728779061_7657189342095595292_n.jpg
    Are you laminating with fiberglass? Otherwise 1/4" is very thin. Seems like a lot of effort to save a deck. You could try lifting strakes.
    ondarvr likes this.
  3. Geno67
    Yes. 6" roll at seams and 12 oz biax sheathing.
  4. kapnD
    Likes: 558, Points: 113, Legacy Rep: 40
    kapnD Senior Member
    I think you can make improvements without replacing the hulls.
    Move the fuel and batteries forward first.
    Then maybe try large lifting strakes.
    bajansailor, Geno67 and jehardiman like this.
  5. jehardiman
    Likes: 1,483, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    That's the first thing I'd do.
    Note that to lift onto plane most vessels (and all displacement hulls like these) need to have some bow up angle to them. 18' and 30 knts is actually doing pretty good; you would really, really need a good design to push much beyond that.
  6. Ad Hoc
    Agreed, don't fix what ain't broke!
    However, if after all that you're still not convinced or require more buoyancy and/or speed.
    You could try the following:
    Extend the aft section, for additional volume, by the amount of buoyancy you calculate that you need.
    Then shape the lower part to be a shallow Vee....with the Vee slowly changing shape as it goes fwd to butt and blend into the circular shape.
    The "chine" part of the Vee, could then butt into a spray rail/chine that is added fwd of the extension by around 1/3 rd length of the hull that extends fwd to help facilitate better flow at higher post hump speeds.
  7. ondarvr
    Likes: 699, Points: 113, Legacy Rep: 506
    ondarvr Senior Member
    That's a lot of money, effort and time for limited improvement.
    Buy another full or partial length pontoon and bolt it in the center, they are readily available. Or buy a different boat altogether.
    We extensively modified a pontoon boat for guiding purposes, they are cheap and easy to find. We didn't go with an 18' because they suffer from that exact problem, and there's no great fix for it. The next size up works far better.
    bajansailor and Geno67 like this.
  8. Barry
    Likes: 636, Points: 113, Legacy Rep: 158
    Barry Senior Member
    Or unbolt the pontoons and rebolt them further back.
  9. HelmutSheina
    Likes: 8, Points: 8
    HelmutSheina Junior Member
    Found similar with a different style of power cat, the 18' was hard to like and the cut and stretched 20' did the job very well.
    ondarvr likes this.
  10. Geno67
    Thank you gentlemen for the information. She runs 30mph - about 26 knots which is quite good. She's been lightened about as much as can easily be done. All furniture removed, 1/2" exterior decking instead of 3/4".
    The engine is a bit low - it throws water on the deck above 20 mph so the engine height needs adjusting but I wanted to get any changes that would affect how she level sits done before moving the engine. Once that's done, I'll optimize the prop. I think strakes will be in her future after that.
    I'm thinking I'll put a partial third pontoon under her at the rear with an engine mount.
  11. kapnD
    kapnD Senior Member
    Those hydrofoil plate devices that attach to the outboard might help.
    They are not the cure all that they are touted to be, but in some instances they can improve performance.
    It would be a low dollar gamble to try?
    1. DickT
