Wishbone Boom Versus Conventional Boom
Discussion in 'Sailboats' started by Doug Halsey, Apr 25, 2007.
  1. Paul Scott
    Likes: 120, Points: 43, Legacy Rep: 84
    Paul Scott Senior Member
    Bill, do you have a pic or diagram of the flow around an uni rig that shows the twist characteristics? A full foot. I was so close, yet so far....again.....
    Paul
  2. Hansen Aerosprt
    Likes: 0, Points: 0, Legacy Rep: 29
    Hansen Aerosprt Junior Member
    Paul:
    No flow diagrams but here is a pic of the Wyliecat 17 on the wind.
  3. Paul Scott
    Bill, that really looks right.
    Paul
  4. sigurd
    Likes: 8, Points: 18, Legacy Rep: 65
    sigurd Pompuous Pangolin
    What is "inhaul" on a windsurfer?
    Here are some vang/outhaul that don't require any tracks.
    No topping either - but separate mast bend control sounds nice!
  5. Paul Scott
    Sigurd, I think you're asking Bill, but FWIW, mine all went to the end of the boom. More leverage there.
    Paul
  6. Hansen Aerosprt
    Sigurd:
    In-haul on a windsurfer really doesn't have much meaning anymore. Originally, it was the line used for lashing the boom to the mast. I use the term to refer to the opposite of outhaul where a sail with a full batten in the foot can be artificially shaped by compressing the batten against the mast. We do this on the Wyliecat 17 and 30 by moving the tack attachment aft some distance from the mast and 'in-hauling' it to develop shape (or remove it) when desired. On the Laser Turbo we are doing it at the clew because the sail has camber inducers.
  7. Hansen Aerosprt
    Laser Turbo is wide sleeve, 4 camber inducers on std. mast & boom.
    Wyliecat 30 sail is on std mast and rigging.
    Bill Hansen
    Hansen Design
    Recent Projects:
    Wyliecat 30
    Wyliecat 17
    Wylie 'Taxi Dancer'
    Hoot Dinghy
    Laser Turbo
    Antrim Wing Dinghy
    Cal-20+ Unirig
  8. sigurd
    I was wondering, on the camber-induced sails, do they neceserily "flopp" over when they tack, like the full-battened sails, or can they become flat when they have zero AoA?
    I am trying to figure out how to make a softsail transition smoothly through zero AoA, with little dead zone between positive and negative lift.
  9. Hansen Aerosprt
    Yes, the cambered sails "flopp." It can be reduced by outhauling the sail until flat (if possible) before tacking or jibing but why worry about it?
  10. sigurd
    tail elevator/rudder. I figure it can be shifted through neutral smoothly if outhaul (camber) is connected to sheet (AoA) somehow.
  11. Paul Scott
    Bill,
    Is that a stock Laser Mast?
    How much sq ft?
    What is the performance difference to the stock sail?
    Am I off topic now?
    Paul
  12. Hansen Aerosprt
    Some version of a Hoyt boom would probably accomplish what you are after.
  13. Hansen Aerosprt
    Paul:
    Answers:
    Yes. Stock rig with class legal controls.
    100 sq-ft.
    Much better. More responsive to sheeting, easier to control, extends through lulls or turbulent wind better and according to the test crew, 'a whole new gear' is found.
    Yes, to some extent.
  14. Paul Scott
    Bill, better, tighter upwind, more heighth?
    Paul
  15. Hansen Aerosprt
    We are still in the testing stage with several skilled sailors (lightweight junior sailor and heavyweight adult.) No comparable boat-on-boat so the results are subjective but very positive on all points of sail and conditions (so far.) Capsizing tests are also part of the testing. I think if you look at the pic, there is no doubt that it is an improvement.
