Wiring Stereo To Ignition?
Discussion in 'Inboards' started by CRUSADER25, Jul 17, 2006.
  1. CRUSADER25
    CRUSADER25 RYAN
    I Just Recently Bought A 1973 Mastercraft And The Stereo's Power Wire Is Connected Directly To The Battery Which If Left On Will Run My Battery Down. Is There Anyway Of Wiring It To The Ignition Switch To Power On Only When The Boat Is On?
    Thanks For Any Help,
    Ryan
    Likes: 1,726, Points: 123, Legacy Rep: 2031
    You can connect it to the accesory on the switch if it has it. Connecting it to the ignition switch may overload the feed wire depending on what power you require.
