Wire Foam Cutter Using Train Transformer
Discussion in 'Boat Design' started by BobBill, Jan 28, 2023.
  1. BobBill
    Likes: 25, Points: 28, Legacy Rep: 157
    Location: Minnesotan wakes up daily, in SE MN, a good start,
    BobBill Senior Member
    Anyone tried or have advice?
  2. messabout
    Likes: 606, Points: 113, Legacy Rep: 1279
    messabout Senior Member
    A train transformer may, or may not, not have enough ampacity or voltage to light up the cutting wire. But that depends on the total resistance of the wire that is being used.
    Watts = amps x volts. If the transformer has an output voltage of say...12 volts, its output capacity is 5 amperes then the maximum output is 60 watts. That would be enough to light up a very short and very small diameter wire.
    An ordinary automotive battery charger is likely to have a lot more output capacity than the train transformer.
  3. wet feet
    Likes: 651, Points: 113, Legacy Rep: 124
    wet feet Senior Member
    The best place to seek advice would probably be a forum for model aircraft.
  4. BobBill
    Been! 60 is heavy and merci to all!
