60' race sailboats NO KEELS???? HOW
Discussion in 'Boat Design' started by 7393452, Jan 29, 2007.
  1. 7393452
    Likes: 0, Points: 0, Legacy Rep: 7
    7393452 Junior Member
    i looked at race sailboats on the web ans they have no keels. just twin rudders and twin dagerboards
    why don't they tip over??:confused:
  2. wet feet
    Likes: 651, Points: 113, Legacy Rep: 124
    wet feet Senior Member
    Probably water ballast.
  3. marshmat
    marshmat Senior Member
    What type of race sailboats? Catamarans perhaps?
    But seriously... if you're thinking monohulls, you might simply not be seeing everything- mono racers usually have a big heavy bulb on the end of a very long thin strut, instead of the more familiar fin or long keels on cruising yachts... and that keel is often removed when on land, because otherwise the boat's too high up to comfortably work on... then there is of course the water-ballasted Mac26x lake boat, which we are told can beat the stuffing out of every fixed-keel raceboat there is :D
