Tom G Sailor
New Member
- Joined
- May 17, 2022
- Posts
- Reaction score
- Location
- Rochester, NY
I have a CT42 Mermaid that I will be installing a horizontal windlass onto. The problem is that the anchor sits out on a rising bow sprit and the deck is below a high bulwark/gunnel rail. It's such that from the anchor roller to the deck is a 17" drop within 6 ft anchor chain run. That's about a 15 degree anchor chain angle. The max the windless specs for chain grab is 5 degrees.
Is there a better way to mount the windless other than my current plan of building a wood pedestal ~ 12" tall mounted to the deck and putting the windless on that?
If cut a hole in the bulwark to pass the anchor through, the anchor will still be sitting high on the bow sprit and have to come down through that bulwark opening. If I drop the anchor down &/or closer to the haul, the anchor and chain will risk hitting my "Mermaid" on the bow and fowling on lower bowsprit cables running to the haul.
