Will gelcoat fill pinholes?
Discussion in 'Materials' started by Nick Shaw, Oct 20, 2023.
  1. Nick Shaw
    Nick Shaw Junior Member
    After sanding LBI 940 vinylester fairing compound there are a lot of small pinholes. I plan to apply gelcoat over this. Will the gelcoat fill in the pinholes? I don’t want the, “bridges over”. Should I fill them with a low viscosity filler? What’s the best filler for this purpose?
    Thanks
  2. ondarvr
    Likes: 661, Points: 113, Legacy Rep: 506
    ondarvr Senior Member
    It all depends on what you mean by pin holes. Typically pin holes will be bridged over for the most part if they're small.
    You can squeegee gel coat over the surface and force it into the pits right before spraying. This works, but becomes a little more difficult as you scale up in size.
  3. Nick Shaw
    The pin holes are maybe 0.5mm diameter. Do you think it’s good just to use the squeegeed gel coat? … we’re planning on rolling on the gel coat since it’s below the water line and will get an epoxy barrier coat on top before antifouling. Or would it be better to use some other low viscosity fairing compound also squeegeed on prior to gel coat?
    In spite of reading otherwise Im a little concerned about using an epoxy product then gelcoat. Am I being paranoid…..many posts seem to say gelcoat adheres to epoxy just fine.
    You may ask why gelcoat at all…it was planned to use vinyl ester gel coat followed by epoxy barrier as a “belt and suspenders” effort to be more water proof.
    Thanks
    Comments?
  4. Nick Shaw
    I should add that the guys doing this job for me are complaining the LBI fairing compound is too hard to sand. I can empathize but it was the product they recommend.
  5. ondarvr
    There is no need for gel coat if you are going to use an epoxy barrier coat.
    kapnD likes this.
  6. kapnD
    Likes: 505, Points: 113, Legacy Rep: 40
    kapnD Senior Member
    You’re still in the fairing/sanding phase, why not fill those pinholes now, before painting?
    That’s the kind of thing that shows up as blisters over time.
  7. Nick Shaw
    That’s my thinking. Hence my question…. Will VE gelcoat fill them or should I use more of the same LBI 940 VE fairing compound? The guys doing the sanding are complaining it’s very hard to sand. Strange as the manufacturer claimed is sands easily. I’ll be phoning them (LB I) tomorrow morning to see what they recommend.
  8. ondarvr
    Gel coat will typically be much harder to sand than any type of fairing compound.
  9. kapnD
    kapnD Senior Member
    hmmm, that makes me wonder if your guys know what they’re doing?
    Are they using professional sanding tools with correct sandpaper?
    Fairing compound does get harder over time, I like to sand it as soon as practical after application.
    Hardware store sandpaper sucks!
  10. Nick Shaw
    They’re supposed to be professionals but I’m seriously wondering
  11. ondarvr
    Maybe we need to know a little bit more about the entire project because some of the information doesn't make sence.
  12. kitcarman
    Likes: 1, Points: 3
    kitcarman New Member
    From my experience (which is limited to kit cars using polyester resins and gelcoats)...... filling gelcoat pinholes is very difficult and tedious. I've found the only way is to prepare the area by cleaning with acetone, and then drip some gelcoat onto the pinhole - this WILL NOT successfully fill the hole unless you do the following. Take a small implement eg a thin strip of timber (coffee stirrer?) sharpened to a point, and direct this through the liquid gelcoat into the pinhole and agitate it to ensure any trapped air is removed. A long and tedious process - maybe if you have the equipment car screen fitters use to 'vacuum' an area to introduce resin and repair cracks, that would be a way to make it easier to resolve.
  13. sharpiedory
    sharpiedory Junior Member
    Pinholes are annoying.. worth taking the time to putty generally. With good technique a pinhole can be puttied leaving little to no extra to sand off.
