ben2go
Boat Builder Wanna Be
- Joined
- Jul 7, 2008
- Posts
- 187
- Reaction score
- Location
- Upstate, South Carolina,USA
I am about to start building a motor barge. The center section of the hull is somewhat flat. There is some shape with round chines. The ballast will need to be between 3 and 6 tons. I've been researching ballast location. I've read an interesting article about keeping ballast more dispersed and toward the outer hull to help prevent snap roll where the boat rolls to the side and sharply snaps back upright. I want to prevent this. The same article went on to say that weight toward the ends of a boat can cause excessive pitching in a rolling sea. If the ballast was added outboard from the centerline of the boat, along the center of gravity, wouldn't that make for a pivot point and cause the tetter tottering effect to worsen? I'm trying to nail down how I need to ballast my boat so I can add in ballast block compartments to contain the ballast and prevent their movement.
