sdowney717
Senior Member
- Joined
- Nov 13, 2010
- Posts
- 1,600
- Reaction score
- 118
- Location
- Newport News VA
People should be thicker skinned and not get riled so easily, I know I have learned that lesson.
How about a new concept in engines, a thorium laser powered engine.
Thorium is in plentiful supply enough for thousands of years and even easily mined from dredged muck from oceans.
The thorium laser heats water which then works as a standard steam engine.
And only 8 grams can take you 300,000 miles.
Easy mining of thorium. It is all over the earth.
http://www.ensec.org/index.php?opti...l-alternative&catid=94:0409content&Itemid=342
But would the government allow us to build it?
Laser Heating
http://www.txchnologist.com/2011/the-thorium-laser-the-completely-plausible-idea-for-nuclear-cars
Thorium lasers: The thoroughly plausible idea for nuclear cars.
The LPS power plant, for all its whiz-bang properties, isn’t a complete departure from traditional power generation: the thorium is lased and the resulting heat flashes a fluid and creates pressurized steam inside a closed-loop system. The steam then drives a turbine that turns an electric generator.
A 250-kilowatt unit (equivalent to about 335 horsepower) weighing about 500 pounds would be small and light enough to put under the hood of a car, Stevens claims. And because a gram of thorium has the equivalent potential energy content of 7,500 gallons of gasoline, LPS calculates that using just 8 grams of thorium in the unit could power an average car for 5,000 hours, or about 300,000 miles of normal driving.
