Why not *very* thick core in hull & deck?
Discussion in 'Boat Design' started by u4ea32, Jun 10, 2013.
  1. TeddyDiver
    Likes: 150, Points: 73, Legacy Rep: 1650
    TeddyDiver Gollywobbler
    Yup :D Thou there are other factors too (depending of the construction method used)
  2. brian eiland
    brian eiland Senior Member
    I'd like to hear some more specifics of what you are doing with this relatively thin metal jacket (barge decks) over what sort of 'foam'?
    And why are you using 'alloy' for these barge decks,.... why not steel?
  3. michaeljc
    Likes: 3, Points: 18, Legacy Rep: 18
    michaeljc Senior Member
    Hi Brian
    The advantages vs disadvantages of alloy over steel is well documented so I will not go into this here.
    The concept of metal sheet foam sandwich construction is advantageous in certain applications only.
    It is most applicable to flat profiles where foam pressure can impose a convex surface to flat plate. This increases oil canning resistance e.g. on decks. It also reduces distortion (a major problem in flat alloy) while welding.
    The pressurisation of hollow beams using foam enhances the above plus beam strength.
    Both the above maximise benefit where the plate is thin enough to distort under pressure.
    Cheers
    M
