A II
no senior member → youtu.be/oNjQXmoxiQ8 → I wish
- Joined
- Jun 21, 2020
- Messages
- 176
- Reaction score
- 66
- Location
- Belgium ⇄ the Netherlands
Excluding sidetracks excludes serendipity.
Note: This feature may not be available in some browsers.
I'm fully aware of the concept of delayed gratification, and how the individuals proclivity towards it usually predicts success in life.Here's the first line in full:
‘‘ Many people misunderstand life. They think comfort is happiness, but unfortunately, that kind of happiness only works in the short term because, like drug abuse and instalment purchases, it burns energy intended for your future well-being. ’’
I fully agree to that first line, but would like to express it a little more strongly by replacing the first word with ‘‘Most’’.
However anyone who misunderstands life in that way wouldn't agree to it as long as they misunderstand life, as ignorance is some sort of paradise, at least for the ignorant.
P.S.
‘‘Ignorance Is Bliss’’ is a phrase coined by Thomas Gray in his 1768 Ode on a Distant Prospect of Eton College.
‘‘ - To each his suff'rings: all are men,
Condemn'd alike to groan,
The tender for another's pain;
Th' unfeeling for his own.
Yet ah! why should they know their fate?
Since sorrow never comes too late,
And happiness too swiftly flies.
Thought would destroy their paradise.
No more; where ignorance is bliss,
'Tis folly to be wise. - ’’
If windward ability on the current boat doesn't improve enough when it gets more empty, then on his first stop Sven easily could add an outside keel beam to the hull, glass it over, and continue the journey within a week or so. For ease of keel work the boat is easily to roll over on a sandy or grass soil with the help of a few people.
Well as said, I don't think Sven will go for this, instead in his pre departure post of June 9. 2020 he tells (video start 2:56) to plan for added complexity in his next boat, of which I've posted my thoughts on the thread Yrvind in post #613.Besides Will's idea to use the yuloh as a makeshift leeboard (post #616), I would give the current boat a hollow keel beam just wide enough to contain the freshwater stock and the batteries and the anchors plus anchor chains, accessible through a few sole hatches, but agree, I don't think Sven would go for it.
At the time of this posting Sven's position is about to cross the imaginary line between South Newfoundland and South Biscay, and so is about to leave the Northern North Atlantic, and ± entering the Southern North Atlantic.A shallow fixed long keel on the next design would give the same gain in windward ability as the now planned lifting keel. But with the lifting keel the boat would be able to escape to safety over a shallow bar or reef, where deeper boats get wrecked or simply don't have an escape option there. And at open sea when lying a hull in bad weather the shallow flat bottomed boat with raised keel would be pushed aside by heavy seas, whereas the keel boat would trip over its keel and experience knock downs and rollovers all the time, which is very uncomfortable for the crew and also bad for the rig. Down wind with the keel raised the lift keel boat would be a little faster, because of its less water resistance by less exposed wetted surface. And the shallow boat also has more options to avoid the use of busy and expensive marinas and hide in beautiful little shallow coves, as well as the options of drying out level on the flat bottom while coming as last and going as first. This all comes for the price of a huge added complexity in design and build and use * where Sven all likes to experiment with and don't want to give up on the possible gain options. (* and added maintenance)
To go directly for NZ were pre Covid-19 plans with a planned departure from south west Ireland, leaving from Norway the plans were changed into reaching the Southern North Atlantic and cruise around there till food runs out (the boat was pre Covid-19 already stocked for the trip Ireland - NZ), fresh water stock supplemented by catching rain, and then restock in ± November in eg. Santa Maria in the Azores, and then go for NZ from there.I wonder if he thought with the current covid 19 issues, that he may not have any chance of re-supply en-route ? It is a hella long way to NZ, so many people think those stuck in NZ should just sail back to their home country without touching land on the way back, but I would think trips like that are virtually unprecedented.
No problem at all with sidetracks, Angel, if they don't go on toooo long. I'm absolutely a culprit myself. Its the digression into politics and other contentious subjects that result in testosterone fuelled willy waving (uk colloquialism!) that is less than constructive.Excluding sidetracks excludes serendipity.
No flare in the sides means the boat keeps sinking at the same rate when extra loading, which is no problem if the total center of gravity is kept low, and the load is balanced along the length of the boat, then the extra load only slows down the boat a bit, especially in light airs.. . . . Flat sides mean every extra pound sinks the boat quite much.
