Note: This feature may not be available in some browsers.
For me, if going small was the goal, fast as all possible would be a big part of that. Wide flat bottom that could plane with a good wind will get you across many sections of ocean within a three day weather window. For rougher conditions and the few 4 plus day runs, high deck camber and weighted swing keel with watertight hatches should keep the weather out and you upright.
I'd be looking at a modified crabclaw rig that angled to windward like a windsurfer for spilling excess air and maintaining an upright hull to get the best cross section shape in the water. Maybe the ability to stow the main and fly a headsail and a small removable mizzen for severe weather.
A month at sea would be the extreme, so supplies would be limited. There is about a 300 nautical mile run from Newfoundland to Greenland, after that, everything else, I think, is well under that in distance.
If the Azores or Hawaii are your goals, well, that's a different matter. Just getting from one side of the pond to the other, it shouldn't take that kind of stamina at sea.
I admire and even envy Sven his adventures, but he doesn't approach them the way I imagine I would. To be fair though, I'm not out there and he is. So...
BRAVO!
-Will (Dragonfly)
Here's a quick sketch of the basic idea.Yes, respect to him for doing it but I would be far more interested to see your design than Yrvind's next one.
The westward move seem to have started, there's also a new post from Sven, among some other things he tells to have been at risk of an unwanted "rescue".Sven is now at the latitude of the Azores, he will probably sail further south, then west, and then north east down wind to one of the islands, like he has planned in one of his previous posts on August 7, 2020, 40 days at sea.
‘‘ . . . . I plan to sail south until I get into the northerly winds and then south of Azores, sail west and up to the islands. . . . . ’’
The cockpit would support a dome tent or a spray skirt. The yuloh would have a rotating blade to double as a rudder. Its asymmetry, I think would not be a problem, but I am thinking of a moving pivot to allow for off-center position. The sail is more like a hang-glider wing and I think the CG could be designed so, with the CB up, it was very close to the WL. With a beamier WL than deck width, the draft should remain very shallow. The hard chine rises steeply at the bow so, on a heel, there is less lateral resistance forward and counters the diving effect of a plumb bow.
A transom arch allows for better clearance of sheets and braces and can mount a solar panel. I like the idea of a small removable mizzen for heavy weather sailing and sea anchor riding.
OOPS! I just noticed I drew the sail on the windward side. Oh well, I'm sure you can picture what I meant.
-Will (Dragonfly)
Sailing a high performance boat for days on end would wipe a sailor out. How many hours can one spend hiking out on the rail?
Wow! Now that's kind of what I had in mind. However, I'm guessing they are not solo and can get a little watch relief. Pretty awesome though.The mini-transat skippers do this transatlantic at phenomenal speeds - and their boats are not much bigger than Sven's.
Presentation of the Maxi 650, the new Mini series of the idbmarine shipbuilding yard in Finistère https://www.idbmarine.com/en/maxi/650/maxi650.php
-Will (Dragonfly)
