Free!ship newby
Discussion in 'General Computing' started by Izzy, Jan 8, 2007.
  1. Izzy
    Izzy Junior Member
    I've downloaded freeship. I am not a boat designer but have a riverboat under construction. Another post under desigh forum titled "building riverboat". My question is this. When you put in a new design it always just assumes you want a rounded hull. I'm just dealing with a basic barge with flat bottom and would like to no if anyone has a hull layout similar that would be easier for me to download and make modifications instead of trying to drag all the points around and still have curves where they are not needed. the current barge is 90' by 30' with angles fore and aft and sits about 7'5" into the water.
    Thanks,
    Izzy
  2. Izzy
    Izzy Junior Member
    correction
    The barge sits 7.5" into the water.
  3. reefling
    reefling Junior Member
    im having the same problem with the program.
  4. yipster
    Likes: 98, Points: 58, Legacy Rep: 1148
    yipster designer
    creasing edges does the trick you want
    a flat barge can be downloaded from the design datebase on www.freeship.org
  5. Izzy
    Izzy Junior Member
    Thanks so much for the help yipster. I'll take a look at it.
    Izzy
