Why are sails tall instead of wide?
Discussion in 'Hydrodynamics and Aerodynamics' started by BlubBlub, Jan 26, 2026.
  1. BlubBlub
    Likes: 2, Points: 3
    BlubBlub Junior Member
    Wide seems more stable.
  2. jehardiman
    Likes: 1,482, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    If you want to only go downwind (i.e. AWA ~135-225) wide vs tall makes no difference....Viking longships, Spanish carracks, etc. If you want to go upwind, then it is all in the Aspect Ratio (i.e. span (hoist)^2/sail area). The whole reason for lateen of old and the bermuda rigs we see today. Yes a wide rig has a lower center of effort, but gets less "lift" to windward; so it is a trade-off.....and to go into gaff and tall ship rigs we will need to get into a whole lot of aerodynamic theory about how they work.
  3. CarlosK2
    Likes: 116, Points: 63
    CarlosK2 Senior Member
    Yes
    The sails are tall forming 1 Wing with 2 Elements and effective Aspect Ratio of 3.3 ... because the bias of the modern sailboats (1930-) is beating Upwind
    A) with an Angle of Attack of 25-30 degrees and
    B) a wind speed between 7 and 14 knots
  4. CarlosK2
    It depends on the desired heading relative to the wind (W)
    1 Wing constructed with 2 sails
    Lift: 100 Newtons
    Drag: 20 Newtons
    1, 2, 3, or 5 Sails
    Lift: 100 Newtons
    Drag: 100 Newtons
    1 Parachute
    Lift: 20 Newtons
    Drag: 100 Newtons
  5. CarlosK2
    In other words
    first, we must distinguish three very different planets or worlds:
    Upwind
    Reaching
    Downwind
    and, within the upwind planet, we must distinguish different regions depending on the angle of attack and wind speed
  6. CarlosK2
    Upwind: 1 Wing constructed with 2 Elements: 2 Sails
    Reaching: 1, 2, 3 ... 5 Sails
    Downwind: Parachutes
  7. gonzo
    Likes: 2,317, Points: 123, Legacy Rep: 2031
    Carlos hijacks a thread again with his usual nonsense, giant photos and double/triple spacing to make the posts even larger. His conspiracy theories about the downfall of society because boats can point well upwind are really nonsensical.
    Boats that can't sail upwind are like a car that only drives downhill.
    bajansailor and Doug Halsey like this.
  8. CarlosK2
    Further Offshore
    Further offshore : ocean racing, fast cruising, modern yacht handling and equipment : Illingworth, John H : Free Download, Borrow, and Streaming : Internet Archive https://archive.org/details/furtheroffshoreo0000illi/mode/1up
    The curious thing is that the modern sailing Yacht was born twice: in 1930 with fractional 3/4 rig, and in 1947 with John Illingworth
    And both forms became extinct in the mainstream around 1979
    In other words: the rigging of sailboats depends on which regattas are the most famous at any given time.
  9. CarlosK2
    Beowulf
    Beowulf beat Mari Cha III in the Caribbean, a Yacht almost twice as long, by flying lower sails ... Reaching
  10. CarlosK2
    Why did this motorboat need such an astronomically large mast?
    On a sailing yacht, it's debatable; but on a motorboat... it's simply insane
    Trying to find rationality in this industry is a recipe for melancholy
  11. CarlosK2
    On a distant planet in a far away galaxy ... explorers would find:
    a multitude of small sailboats with fractional rigs (3/4) and large, rotating bowsprits
    a lot of cruisers with chinese rigs
    large yacht with two short masts
  12. CarlosK2
    About Fractional 3/4
    "What's the reason for having the hounds below the tip? Aerodynamically it doesn't make sense, since it promotes local tip stalling as your calcs show. This is why a leading edge slat on a wing always goes all the way to the tip."
    Bell Spanload Implications for Sailing? https://www.boatdesign.net/threads/bell-spanload-implications-for-sailing.59464/page-2
    Yes, exactly
    But the reason is Power/Depowering Control
    in seconds the rig is shorter
    with 1 rope you have
    +/- AoA
    -/+ Camber
    +/- Twist
    and
    -/+ "h": vertical distance Lateral hydroForce - AeroForce
    It's versatility in a changing environment
    The Lift coefficient can be adjusted between 1.4 and 0.7
    And
    At the same time, the rigging can be shortened, which is why the cables don't reach the top.
  13. gonzo
    Carlos, please have some respect and stop taking over threads.
    bajansailor, baeckmo and Doug Halsey like this.
    1. Remmlinger
    2. jmf11
    3. Revboat
    4. Mikko Brummer
    5. schakel
    6. Erwan
    7. Doug Lord
    8. Will Fraser
    9. Heimfried
    10. dustman
