When looking at the displacements of boats of different sizes, you can notice that larger hulls are often somewhat heavier compared to their approx. waterplane area, than smaller hulls.
Bottom loading http://marine.marsh-design.com/content/bottom-loading
This article says that larger hulls can support significantly more weight for their waterplane area without too much compromising planing performance.
Why is that?
Let's say that we have a hard chine variable deadrise planing monohull with these specs:
LWL: 12.8m/42ft
BWL: 3.65m/12ft
Displacement: 10 000kg/22 000lbs
L/B ratio: 3.5:1
Bottom loading: 237kg/m2 / 48lbs/sqft
Waterplane area used for bottom loading calculation is my very inaccurate formula: (LWL x BWL) x 0.90
Now let's make a half scale version of that hull.
This boat will have a LWL of 6.4m/21ft and a BWL of 1.82m/6ft
If we keep bottom loading at the same 237kg/m2, it will have a displacement of 2490kg or 5500lbs.
Assuming that LCG, VCG, COB and other points are roughly in the same place, is there any reason why the smaller hull would be less efficient compared to the larger one?
And if yes, why?
Why is that?
LWL: 12.8m/42ft
BWL: 3.65m/12ft
L/B ratio: 3.5:1
And if yes, why?
