Who can help me to answer this question? re: why use of empirical formulae is common
Discussion in 'Boat Design' started by ali33, Oct 4, 2012.
  1. ali33
    ali33 New Member
    xxxxx
  2. DCockey
    DCockey Participant
    Are you a student? Is this an assignment or exam? Why not complete it yourself?
  3. groper
    groper Senior Member
    was thinking the exact same thing... sounds like an assignment question...
  4. tunnels
    tunnels Previous Member
    Sound like a load of mumbo bumbo rubbish to me . What assocciation does it have with designing a boat for heavens sake ??:mad::confused:
    if it is part of a assignment id sure a hell be wanting a pretty good reason for having any thing to do with it !
  5. gonzo
    Likes: 2,387, Points: 123, Legacy Rep: 2031
    Empirical formulae, in ship design or any other discipline, is based on experimentation. It doesn't address theories of why thing do what they do, but is based on data and verifiable facts.
  6. tunnels
    so isnt important to the joe making a boat !!!why fill our heads with things that are just theory when its fact we need !! cold hard down to earth facts !!that if i do this that will happen and if i do that this will happen because its real . :eek:
  7. johneck
    Likes: 17, Points: 18, Legacy Rep: 117
    johneck Senior Member
    One would use empirical formulas that are based on experience and general practice when details or specifics are unknown or a quick answer is needed. The trick is always to know when the design you are thinking about is within the range where the empirical formulas will work, or not. So it is important to understand the basis for the empirical estimates.
  8. tunnels
    so learn and then forget ???:confused:
  9. Submarine Tom
    Submarine Tom Previous Member
  10. tunnels
    Has it made you a better person amd made you a fortune knowing a bunch of useless information :confused:??
  11. BPL
    Likes: 15, Points: 0, Legacy Rep: 209
    BPL Senior Member
    Beginning of an empirical formula
  12. Submarine Tom
    tunnels, are you frustrated by something?
  13. PAR
    It would be handy if you understood what an empirical formula was folks. It is the direct or indirect absorption of knowledge by observation, which can then be analyzed quantitatively or qualitatively. This is the basis of most research: Assemble empirical facts and form opinion (hypothesis), work through the hypothesis (formulate), establish testable predictions, then testing, then evaluation.
    Ain't science cool . . .
  14. tunnels
    To many big long words i never heard of before ,so the moto of "if you cant convince them then baffle them with science" is alive in your part of the world . personally i dont believe any of it !! it either works or it dosent !!! :eek: When some on hits me with something as complicated as that they usually dont have a bloody clue what its all about :confused:.
  15. tunnels
    Frustrated !! yes i want to go home !!real simple !!:):D:p
