Which one out of these small multi-hull designs will be the best for my needs?
What boat would you choose?
  • Total voters
    13
I mentioned the AS39 as more of an interesting data point than a suggestion - I don't expect Eli would actually want to build one! That said, how do you define "big?" Interior Space? Sail area? Weight? Cost? Slip fees? Time to build? Number of Sheets of Plywood? As an example, at my local marina the slip fees for the AS39 would be $439, while the Duo1000 would cost $459, because there is a 20% surcharge for catamarans. I believe the fee used to be 50%, which would make the difference pretty dramatic.
If Eli is motivated and effective then the Duo 1000 can be built. It's best to be motivated, building to plan and not sweating the details. Otherwise it's best to build the simplest boat that meets your needs to maximize the odds of finishing the build.
Yes, I think that DUO, Tamar or even a Mirage (for center helm) is the direction I am looking at. I like a lot the Eagle, it's such a great design. However as other people commented, with the solar system and hard-top, I afraid it might be overloaded a bit. I did a rough cost comparison, and the difference between the Eagle and the DUO or Tamar is about 15,000$USD in materials and maybe extra 500-1000hrs of work.
Much of that can be saved with proper planning, CNC laser cutting (relatively cheap here) of all parts and using fine mesh high quality peel ply to avoid 90% of the sanding.
I like how Wharram designs look, there is something romantic and magical in them. However, for actual sailing - I prefer the performance and safety of a modern designs in the likes of Woods, Shuttleworth, Bernd, Waller etc...
I am not trying to push Wharram designs or anything else, but I would point out that few homebuilt boats have crossed oceans as often and successfully as Wharram cats and this going back over 60 years. I'd argue that it's the safety and performance of the modern designs that has yet to be proven in many cases. ;-)
60 years since Wharram crossed Atlantic https://classicsailor.com/2019/09/60-years-since-wharram-crossed-atlantic/
I do not think there is anything that makes Wharram cats inherently safer other than the fact that they are not racers and do not carry as much canvas as the rest so are seldom pushed to the edge like other designs which are capable of higher speeds.
Wharram now offers Mana 24 kit, this would be the fastest way for home builder to own a small cruising catamaran if buying used is not an option.
Mana 24 - Self-Assembly 'Cat-Kit' | James Wharram Designs https://www.wharram.com/self-build-boats/mana24
Actually, I would say that cruising cats (not just Wharram's) *are* inherently safer *because* they "do not carry as much canvas as the rest so are seldom pushed to the edge like other designs which are capable of higher speeds". In other words, they prioritize safety and stability over speed.
I had not heard of that Mana 24 kit, what a great looking boat! I love the rig and that would be a fantastic boat for a couple or a family with one or two small kids looking for an affordable if spartan cruiser for some serious adventure.
Here is a good rough time estimate for building 24 ft catamaran, you are in 700+ hours even with all the parts already cut to size.
You spoke about the Harryproa 50, which is a fair bit bigger than the others you are looking at.
But what about the 40'er
EX40 — Harryproa https://www.harryproa.com/ex40
Design being over hauled atm, I would put the toilet in the lee hull (maybe that will be part of the revamp ?)
Yes, I like all the Harryproa designs. Rob has a great vision that I am sure will become more and more common as time passes. It just makes sense.
The 40-footer went through several iterations, even with a proposed folding variant. It is still being revamped, and I waiting to see the result.
Due to the free-standing Carbon masts and Divinycell construction, I think it will still be on the expensive size compared to 30ft plywood cat.
But the prices will come down as more people build them and the molds will be available for reuse.
Actually, I would say that cruising cats (not just Wharram's) *are* inherently safer *because* "do not carry as much canvas as the rest so are seldom pushed to the edge like other designs which are capable of higher speeds". In other words, they value safety and stability over speed.
You can reef sails even on the hottest multi's. Poor judgement and/or adrenaline rush is what gets these boats turtled. It is easier to make fast boat slow than vice versa.
9mm gaboon ply (4.3 kgs/sq m) with 200 gsm/6 oz glass (600 gsm) one side and 3 coats of epoxy (400 gsm) the other will weigh ~5.3 kgs per sq m.
10mm 80 kgs per cu m foam (800 gsm), with 1 layer of 400 gsm cloth each side (2 kgs per sq m) will weigh ~2.8 kgs per sq m. In a lot of places the laminate could be reduced. In a few, it would probably be increased.
If the foam laminate is infused, the weight (and resin) saved will be about 0.8 kgs per sq m, so the end result (2 kgs per sq m) is less than half the weight of the ply.
Both will require the same frames and stringers. If the foam was increased to 12 or 15 mm thick (1.2 kgs per sq m), there would be no need for stringers and non structural frames.
There will be less effort and near zero waste with the foam boat as it is easier to carry, shape and join. If you use foam in a non tortured ply boat, you could cut the foam to shape (no waste from scarphing or puzzle cutting) and make the full length panels with peel plied glass on both sides, then glue the panels to the stringers and frames and tape them. Or, glass the inside, assemble them and glass the outside, which may be less hassle than tabbing and fairing the joins.
Both of which are more work than the Harry method (Intelligent Infusion) in which simple, single curvature, self aligning, non shiny moulds are used to one shot infuse 2 half hulls with rebated lap joins. Bond the bulkheads into one half, glue the other half on. No strongback, setting up frames, fairing, grinding of glass and little contact with epoxy. Include window, beam, hatch and mast cutouts in the infusion to reduce the fit out work.
The cost of foam in Australia is lower than decent ply. Chinese foam, glass, carbon and infusion material are 50% less than locally, probably less again in the USA. Buy resin by the drum from a manufacturer (Dow, Shell, etc), not a retailer (WEST, System Three, etc) and sell any that is left over. I pay $US8/kg ($US32 per gallon) for general purpose epoxy, a bit more for infusion.
Some other considerations for discussion:
•Most rot in plywood boats starts at a screw hole. The rest in unvented or inadequately coated areas. One screw every 300mm/12" along the six unclampable edges on a double chine hull on an 8m (26'4") cat is ~400 screws, and a bunch more for the stringers and frames. If they are left in, each hole should be epoxied before the screw goes in. If removed, each hole should have epoxy filler injected in it.
•The same double chine boat will require 200 m of filletting/tabbing to cover the chines and gunwhales, some of which will be on your knees or upside down. And another 100m around the bulkheads. At least half of it will need fairing.
•There are a lot of consumables (tacky tape, vac bag, infusion medium, perforated plastic, peel ply, tubing) with infusion. Minimise it by using scored foam (no medium or perf plastic required) and reusing old vac bags over the job so the same bag can be used multiple times. The volume of the waste is high, the weight is less than the resin you will save.
•A home built carbon mast is probably cheaper than a bought alloy one (second hand beats both) and no more difficult to build than the rest of the boat. It will be about 60% the weight, which may not be a lot on a 26'ter, but will definitely reduce the pitching.
•Unstayed masts on cruising multis are far easier to sail and cause less crew stress than stayed masts, not least because it is simple to fit a fail safe floating fuse that trips the sheet when the hull leaves the water (either capsizing or pitchpoling) regardless of the wind angle and whether the sheet is cleated, in a self tailer or wrapped around your foot.
•2 masts (schooner or biplane) with no extras may be more expensive (second mast, boom and sail versus headsails, spinnakers, forebeam, seagull striker, winches, furlers and tracks) but remove the need to go on the foredeck, except to enjoy the sun.
•A wishbone boom is cheaper, safer and less effort than a traveller.
•Daggerboards and fixed rudders cause grief. It is usually lighter and simpler to make them kick up.
•Deck sweeping headsails and steering positions which limit vision ahead and to leeward are like driving a car with half the windscreen and the passenger's window blacked out.
•Length is safety. Not only in reality, but in perception. If the crew feels safe, they will be much more relaxed and able to deal with problems. Unless there is a reason not to (build space, marina fees, trailering), make the boat as long as you can. The extensions (and perhaps the hulls) can be narrower and lower and if they are kept empty will add little to the cost or overall weight. Keep the same rig, width and pay load. Top and average speed will increase and the motion will be better. Light air performance will suffer if the wetted surface increases, but reducing the overall weight using the suggestions above will more than compensate.
•A showroom finish will take longer than any other part of the build. If cost is an issue, a coat of high build over a peel ply surface and house paint will get you sailing for a lot less money than weeks of hard labour turning expensive toxic chemicals to dust.
•Two boats of similar size and type and built with similar materials, will weigh similar amounts, take similar time to build, have similar payloads and similar performance, regardless of what the study plans say.
Re Harrys:
Thanks for the compliments.
The EX40 has been redrawn for a client (interesting guy, he's experimenting with including his solar cells in the deck infusion) who wanted a bit more room. It has become 43'. An updated 40'ter will be up 'soon' although the basic boat is the same as the one on the web page. The layout is easily customised (including the toilet in the lee hull, which is where I would put it) to suit whatever you want, as long as the hatches, beams and masts aren't moved without consultation.
Building hours for the C50 are based on the time it took us to build one of the cedar 50'ters and the fact that infusion is far quicker. Judging by the time it is taking the current builders, they may be exaggerated, although all the builders are amateurs, learning as they go and working when they can, so exact hours are hard to track.
We will be building one, maybe 2 of these in Fiji ($US8 per hour labour, $US1,500 per week overheads, $US37,000 for the composite materials incl masts) later this year.
The costs, weights, time, waste (aiming for zero due to our plastic recycling operation) and carbon footprint will all be recorded. The build will be video'ed, so stay tuned. Meanwhile, for the reasons mentioned above and others, I'm confident the build time will be significantly less than that of a similar size boat built with conventional techniques. And far less physical.
Excellent response Rob, you have a minor typo which may confuse inexperienced folk.
"Unstayed masts on cruising multis are far easier to sail and cause less crew stress than unstayed masts"
OOPS. Thanks. I have corrected it.
Thanks, Rob, for a hugely informative post. This bit intrigues me, though, as I have never seen anything like it. Do you have any pics and/or can you point the way to a good source to learn more about such an automatic sheet-tripping system? Cheers, Matthew
No decent pictures, sorry and as far as I know, no one else is doing it. It's pretty simple. A stick with a weighted float on one end and a hinge pin on the other is mounted near the stern. The hinge pin is extended and has a cam cleat on it. The sheet release is in the cam cleat. If the hull lifts, the float drops, the pin rotates and the cleat opens, releasing the sheet. More or less the same system foiling moths use to control their foil angle.
The system should be between the boom and the winch. On my test boat (a Harryproa so the rig was on the leeward hull), the sheet ran from the boom to a block on the windward hull, then to the winch. Between the block and the boom, is another block with a tail. This is tensioned so the sheet forms a large V. The tail is cleated in the cam cleat. When it releases, the V straightens, easing the sail.
Works best with:
•A vanged mainsail so the the mainsheet is only altering the angle of attack, not providing leech tension. ie a wishbone or ballestron rig. Leech tension loads are significantly higher than aoa loads with a typical multihul sail so the cam cleat needs to be more substantial and the float more buoyant.
•An unstayed mast. When broad reaching and nosediving, easing the main onto the shrouds as the boat slows and the apparent wind moves aft is probably not going to help. An unstayed mast allows the sail to swing round and weathercock, regardless of the wind angle.
• Main only rigs. Flogging headsails and sheets are dangerous.
• The system mounted below the bridgedeck so no one is standing in the V and there is nothing for the released block to thump into.
•Maybe a variable length stick so you can allow for waves, although a longer skinnier float would do a better job.
In theory, once the system was tested (statically by submerging the float or ultra carefully by flying a hull), there is nothing that could go wrong and lead to a capsize, which would make multihull cruising a lot more relaxing (and faster if you were not always reducing sails). In practice, I may have missed something. ;-). I would welcome discussion of any potential problems.
To those who took their time reply in this thread so far,
Thank you. You input is greatly appreciated.
Regards.
Eli.
Hello Eli,
Have you seen Pete hill's Oryx? She is a modified KD860 Lengthened to 10m. Average cruising weight 9000lbs.
Its a free standing twin masted junk rigged cat. One problem is the low headroom in saloon.
All the very best for your build.
