Where to locate transducer w/ kicker & trim tabs
Discussion in 'OnBoard Electronics & Controls' started by the brain, Apr 1, 2017.
  1. the brain
    Likes: 4, Points: 18, Legacy Rep: 10
    the brain Senior Member
    I understand w/ my main engines propeller being clockwise (standard rotation ) the ducer must be located on starboard side.
    That being said when I add a kicker am I forced to mount on port side?
    I was planning on mounting the kicker to starboard side then attach lower section of ladder to dive platefowm on port side.
    Edit : I have added trim tabs.
    Thanks TB
  2. the brain
    anyone
  3. PAR
    A transducer can be mounted in the hull, if desired. I would also think you could mount it forward of the kicker's lower leg. Rig it up and have a look. I'll bet you can squeeze it in there, in spite of it looking too tight currently.
  4. the brain
    I have read that inside hull transducers won't work inside a aluimin hull only fiberglass hulls.
    want do you think about the magnetic type ducer mounts I would like the option of removing when not being used.
