sdowney717
Senior Member
- Joined
- Nov 13, 2010
- Messages
- 1,600
- Reaction score
- 118
- Location
- Newport News VA
In my old timber framed boat, the oak floors that sit on top the keel are pinned with long steel spikes to the keel. Those spikes are causing problems as boat is 52 years old. The spikes are rusting away and also causing parts of the oak to rot with perhaps iron sickness. I have so far repaired 2 badly rotten floor timbers due to the bottom part of the floors turning into black mud. It was a pain but I did a good repair and now those floor timbers are very solid. I cut off the bottom part of the bad wood into the solid oak all along the floor and at the good top part of the floor glued and screwed oak boards on each side of the floor timber leaving the nasty iron spike idea out of the repair. And I replaced the lower part of the floor with glued in pieces of PT SYP with a tight grain patter. IMO, the 2 floors are actually much stronger than new as they are no longer pierced all the way down the middle with a badly rusted oak sickness inducing steel spike. I would really like to yank out a bunch more of these steel spikes as I know they are causing future issues with rot on several other floor timbers. My idea was to drill down the steel spike with a long core drill and then would be able to simply pull out the spike.
It will take about 9 or 10 inch long core drill to do that, preferably a foot long for some possible other floors are deeper. So anyone have an idea of how to remove those steel spikes? They are like very large timber nails and are 1/2" in diameter.
I have thought about cutting a core drill in half and welding in a steel tube to make a longer core drill. Course that is a lot of effort. A core drill will follow down the straight steel spike, loosen it from the wood and make it easy to remove.
I donit believe those steel spikes do anything after the boat is constructed, they aided in the original assembly of the boat to keep things aligned. The floors are screwed into the frames and planking, and some are bolted to the stringers that sit on them.
