Where can I find inexpensive Buss Bars?
Discussion in 'Electrical Systems' started by CLUTCHfan, Apr 6, 2007.
  1. CLUTCHfan
    CLUTCHfan Junior Member
    The only Marine supplier in my area that carries them wants my first born son for Buss bars ($35-$40 apiece) I found a place on ebay, but would rather buy from an actual online store/distributor. I didn't know if there was an online store that people have had good experiences with that had good deals on electrical components for my boats.
  2. KnottyBuoyz
    Likes: 55, Points: 0, Legacy Rep: 685
    KnottyBuoyz Provocateur & Raconteur
  3. Frosty
    Frosty Previous Member
    You may think that only boats use them --I did.
    Try your local electric store. I can buy them here very cheap at any electrical shop.
    Square brass bar with tapped hole and screws and two plastic ends to support them.
  4. tja
    Likes: 1, Points: 18, Legacy Rep: 11
    tja Senior Member
    Tja
    Hello, What size do you need. I buy at OEM pricing and could give you a good discount. Tom.
  5. Lancerbye
    Lancerbye Junior Member
    Check your electrical wholesaler they should have them in brass with brass screws or in copper(1/4")x 1"or bigger 3 to 8ft strips. Stay away from marine supply stores for this. They usually mark them up by about 400%
  6. PAR
    Likes: 366, Points: 93, Legacy Rep: 3967
  7. Carioca
    Likes: 2, Points: 0, Legacy Rep: 26
    Carioca Junior Member
    Initially, I used to buy my buss-bars at marine chandlers.
    Now I make my own, boring and tapping copper strips of the required thickness, width and length.
    For good measure, the copper strips are then tinned in a crucible holding molten solder. Dip the strips into the bath and wipe off excess molten solder with (clean) cotton fibres (stuff that mechanics use). As you wipe off, you will notice the solder clinging to the copper strip.
    The tapped holes are finally cleaned out with a tap tool and all is ready to go !
