where can I find hydraulic fittings
Discussion in 'Materials' started by Mark Emaus, Aug 24, 2010.
  1. Mark Emaus
    Likes: 2, Points: 0, Legacy Rep: 20
    Mark Emaus Junior Member
    Does anyone know of a wholesale company that will sell welded hyd. fittings for steel or aluminum tubing?
    thanks
    Mark
  2. SamSam
    Likes: 198, Points: 63, Legacy Rep: 971
    SamSam Senior Member
  3. Mark Emaus
    I was hoping to have pre made fittings that were welded. Again does anyone know where I might get welded fittings?
    thanks
    Mark
  4. wardd
    Likes: 37, Points: 0, Legacy Rep: 442
    wardd Senior Member
    why do they have to be welded?
  5. SamSam
    Fittings connect things. Welded ones are already welded to something. Maybe you want weldable fittings? What kind, what size, how much pressure?
  6. Mark Emaus
    looking for 1 inch male JIC that can be welded to 1 .25 inch pipe to withstand 3000 psi
    thanks
    mark
  7. wardd
    wardd Senior Member
    I'd use schedule 40 or 80 threaded pipe and fittings
    or stainless high pressure tubing flared
    3000 pounds is nothing to play with, a pin hole leak will slice and dice you
