The rudders on Elan are pretty angled, base on the available pictures I would say close to 15° (
http://www.basicsailor.com/wp-content/uploads/2013/04/Elan-350-e1364839685143.jpg and
http://i667.photobucket.com/albums/vv40/ceeceebee_photos/elan21.jpg).
In order to establish the benefits of their configuration, a further consideration has to be added to what Eric has written (great info as always, btw).
As the boat heels, the effective rudder area (the one which produces the side force) varies with the cosine(heel) law. On a single-rudder boat the variation is negative (less lateral area with heel). On a twin-rudder boat with rudders angled outwards by 15°, the lateral area increases with heel. Just as Eric said in his post.
But, as the boat heels, the yaw moment from sails generally increases (see here:
http://www.boatdesign.net/forums/boat-design/weather-helm-heel-question-50598.html#post691028). The rudders task is to balance the increased sail-induced yaw moment. However, the single-blade rudder has to do it with less lateral area available. Therefore, the tiller angle of the single-blade rudder has to increase in order to compensate for this missing area. The twin-blade rudder angled outwards, having more lateral area at heel, needs a smaller tiller angle increase to achieve the same effect.
Now, the induced drag of the rudder is proportional to the tiller angle squared, everything else being equal. So the twin-blade rudder like that of Elans will have a double frictional drag (in the worst case of a completely-submerged windward blade), but will also have a much smaller induced drag than its single-blade counterpart. Whether it is beneficial or not, will depend on the global boat-resistance analysis, referred to the design goals. At the end, the detailed analysis might prove it beneficial even without the windward-blade kick-up capability.
The above explanation considers the same geometrical blade area between the single and twin rudders, which is not strictly true but gives an idea of parameters which have to be considered. The blade areas of a twin rudder are usually smaller than the blade area of the single rudder, because in a heeled condition the twin rudder blade operates in a better condition for creating the side force.
Finally, a consideration has to be given to the blade aeration too. A single-blade, centrally mounted rudder will be more exposed to the effects of the blade aeration, but also to the adverse effects of the water aeration in the proximity of the sea surface. It can make a difference between broaching or not broaching in some conditions, in particular when the sea gets rough.
Cheers
