What type of 4-8 metre hull for speed around 30-35 knots in calm water?
I m thinking about using series 62 planning hull with deadries angle at 12.5 degrees.
There will be two spray rails rubbed below and parallel along the waterline from section 0 (FP) until the midship. The chine rail will be located from midship section to Ap Have u had any suggestion? Thank you
and what's going to happen when that calm sea has a 1m chop due to some wind on the sea.
For a family boat?
What HP you want to use?
can you be a little more specific in lenght?
The engines are gonna be outboard motors. The first assumption of the length is 33 feet.
I ll try to let the beam and draught vary in case of not enough buoyancy.
The M.V. Minnow had the right lines for this, it carried seven passengers.
? it is probably me but 33ft is 10.05 meters.
Good luck
