what size motor?
Discussion in 'All Things Boats & Boating' started by 14ft, Apr 5, 2011.
  1. 14ft
    14ft Junior Member
    i have a 14 ft jon boat that has about 200 pounds of equipment including myself, and i want to know what size motor
    Likes: 1,814, Points: 123, Legacy Rep: 2031
    Whatever the builder's plate indicates.
  3. JLIMA
    Likes: 4, Points: 0, Legacy Rep: 130
    JLIMA crazed throttleman
    For most jons a 10hp will push pretty well.....but I agree with Gonzo check the builders plate.
  4. michael pierzga
    michael pierzga Senior Member
    Yup , ten hp sounds good. If you can, find a lightweight 2 stroke, keep your gas tank forward and make a short tiller extension . Small craft dont like weight...you the motor and tank in the stern.
    the little yamaha 8hp 2 stroke has a great power to weight ratio. The small Merc 2 stroke..9.8 hp I believe.... has the gear shift built into the twist grip throtle handle. A very fine small boat motor
  1. Chickadee
  2. oceancruiser
  3. djaus
  4. wakeboarder61
  5. troy2000
  6. Squidly-Diddly
  7. hoytedow
  8. cluttonfred
  9. joda235
  10. DCockey
