Note: This feature may not be available in some browsers.
Yes, good point. I already considered this. Hence, the idea of doubling up beams OR using more beefy beams in the engine area. I'm trying to keep everything uniform in terms of Beam height. For example, use 6061 T6, 4" X 3 X 0.326 thick in engine area, 4" X less beefy in all other cross members. Lots of variables to consider, Main concern is ensuring enough support overall, and specifically in the engine area. Thanks for your help.Another thing to consider is whether the entire structure needs to be built of the same material or whether it is wiser to beef up the engine area.
Fallguy, again thanks for the assistance.... Yes, intuitively I would think 1/8 " deflection is the most you'd want to see on a beam with a 600 lb load. The responses here are helping me to zero in on the engineering involved without understanding the nomenclature. As I understand, I have a load being supported by beams, the main consideration is Maximum Deflection (the main point Maximum ALLOWABLE Deflection). Therefore, the whole exercise here is to determine this value. Given that I will be purchasing 6061 T6 I beams, 3" or 4" height. Max Deflection is considered against loading per beam. For example, engine mounted b/w two beams, then 600lb engine load/ 2 = 300 lbs load per beam, Yes? or if beams are doubled then 600/4 equals 150 lbs per beam. Am I looking at this the correct way???I apologize I do not know allowable deflection limits for the beams, but my gut hunch is somewhere around 1/8" max which seems like much to much when written. And this is why I would start with the 600 pound point load. It is only a starting point. Enter the load. Enter the beams. And run the calcs to see deflections. Then you will develop some intuition about how much each beam choice supports the work. It is back of napkin. We have an expert that posts here, but he is on a time difference and doesn't always jump in to all questions.
'fredrosse'. Thank you! Which is why I am seeking out a professional to make the relevant determinations. The good thing with this forum is that it has given me sufficient info to educate myself on the subject matter and more accurately state the Question, and the desired outcome. ) Now I just gotta find a PE that does this sort of thing ).I have been a Registered Professional Engineer for several decades, and with these credentials I can firmly state that the original question is very incorrect on several counts. As Gonzo, and others, have stated, the design of structures requires technical considerations far beyond classic simply supported textbook beam models. Trying to cram all of the technical considerations relevant to this design into a few forum replies is not going to produce results that are reliable and safe.
Rather than work this out from first principles, it would be easier to look at examples of successful boats that have similar loads in similar work conditions.
