What kind of paint on the interior?
Discussion in 'Materials' started by andysailor, Jan 12, 2019.
  1. andysailor
    Likes: 2, Points: 8
    andysailor Junior Member
    The interior has been painted with a latex paint before. I have sanded all the area very good.
    ...but paint what shall I use this time? I'm not a huge fan av the latex....but going alkyd oil based, yeah than I have yellowing to think of....and polyurethane 2 comp...well, that might not stick to the surface very good? What kind of paint would you put on? It's from hip height and down...
    Likes: 2,341, Points: 123, Legacy Rep: 2031
    I prefer water based acrylic paint for bathrooms. It is moisture and mildew resistant.
  3. BlueBell
    Likes: 1,293, Points: 113
    Glossy if it's a dark area.
  4. Mr Efficiency
    Alkyd over acrylic is not a good idea, re-do it with a washable acrylic.
  5. andysailor
    Likes: 2, Points: 8
    Sounds like I should go with water based acrylic
    Do you think the result would be much different if I use an air-conditioner to keep the temp low? ...cause its about 30C + here in the tropics.
  6. Mr Efficiency
    Just thin the paint sparingly with water, till it brushes freely. A good idea is to dampen the brush right up into the stock, not too wet though, before use, which helps prevent "clagging" of the brush, and make the clean-up of your brush easier.
