Note: This feature may not be available in some browsers.
Good point, also this way only the bottoms of the deeper cat sections need to be strong enough for grounding.The benefit is beachability without hard grounding friends. The two deeper cat sections hit the beach first, and thus create a situation where the entire vessel does not ride up onto the shore which would require more reverse to overcome the frictional drag of land.
The lines aft suggest an intent to plane, if just to potter around slowly, they'd be better to sweep up at the stern. Given the low or non-existent clearance, and especially forward, it would be wet and slam.
