What is the best marine plywood
Discussion in 'Materials' started by rugludallur, Jul 29, 2008.
  1. apex1
    apex1 Guest
  2. tom28571
    tom28571 Senior Member
    Marine grade Lauan was once available but I have not seen it in years. Lauan is somewhat more durable than Occoume and other characteristics are similar or better than Occoume. There was a stir of something called Kerrung a couple years ago. The weight alone was enough to keep me away as it was at least 40% heavier than Occoume. Types and sources of marine plywood has always been a moving target. I know of no source for definitive information on all types of plywood.
  3. cookie munster
    cookie munster Junior Member
  4. cookie munster
    For Ocoume, from a French manufacturer:
    Propriétés mécaniques
    Charge de rupture traction 30 MPA
    Charge de rupture flexion 40 MPA
    Module d'élasticité 4000 MPA
  5. jmolan
    Likes: 2, Points: 8, Legacy Rep: 65
    jmolan Junior Member
    Cookie Munster, Thanks, I am also trying to get "numbers on the difference in weights between Ply and foam/glass. I prefer to work in Ply, but I want to be realistic.
    Thanks you for the links. It looks like this one link:
    http://www.nordcompensati.com/en/compensati.html
    Will take me to many Plywoods I can compare. I recently saw one of the
    first design sheets to quote a boat in Plywood and foam/glass
    http://www.teamscarab.com.au/scarab22/design.html
    As you can see the weight difference is not small. +28% (if my math is right)
    I am not sure there is even a "rule" like, well in ply it is 25% heavier, but
    price is equal and less labor. Like I have said, many variables.:confused:
    for a 6.7 tr. Trimaran. Foam= 420 KG. and Plywood = 540 KG. 120 KG.
    difference. Or 22% I am not sure. I understand there are a lot of variables.
    How well a guy will use the materials for maximum strength to weight issues.
  6. cookie munster
    Although using multiple materials does have advantages, it also requires a lot more craftsmanship. don't want to discourage you, but it's something to keep in mind....
    Good luck :cool:
  7. lwolstenholme
    lwolstenholme New Member
    Here are some distributors that stock marine ply. The BS1088 Okoume, BS1088 Hydrotek and BS6566 Aquatek:
    ATLANTIC PLYWOOD, MA, ME 800-360-3923
    CONNECTICUT PLYWOOD, CT 860-953-0060
    ROBERTS PLYWOOD, NY 631-586-7700
    WOODFORD PLYWOOD, GA 229-883-4900
    McEWEN LUMBER, NC 919-772-7550
    SEAFARER MARINE, FL 954-763-4263
    RIVERSIDE LUMBER, LA 504-242-6626
    RARE EARTH HARDWOODS, MI 800-968-0074
    HOUSTON HARDWOODS, TX 713-686-6176
    FOREST PLYWOOD, CA - 714-523-1721
    ALMAQUIST LUMBER, CA 707-668-5652
    McBEATH HARDWOOD, UT 801-484-7616
    CROSSCUT HARDWOOD, OR 503-224-9663
    PLYWOOD TACOMA, WA 253-383-5571
    WEST WIND HARDWOOD, BC 800-667-2275
    LL JOHNSON LUMBER (MI) - 800-292-5937
    SEAFARER MARINE (FL) - 954-763-4263
    HOMESTEAD HARDWOODS (OH) 419-684-9582
    E-BOAT (FL) - 772-770-1225
    RUSSELL PLYWOOD - 610-374-3206
    PLYWOOD & DOOR (IL) - 708-354-2155
    STRAIGHT LUMBER (CO) - 303-366-3561
    ML CONDON LUMBER (NY) - 914-946-4111
  8. peter radclyffe
    Likes: 111, Points: 73, Legacy Rep: 680
    peter radclyffe Senior Member
    bruynzeel ply from holland
  9. apex1
    apex1 Guest
    Hey,
    I´m missing the EU suppliers!:D :D
  10. gonzo
    There used to be a lightweight ply with balsa core. Is there any manufacturer still making it?
  11. apex1
    apex1 Guest
  12. kaakre
    kaakre Junior Member
    LL Johnson / Johnson's Workbench
    I noticed that LL Johnson was listed a a source for marine ply. Just a note to advise of my experience with these guys. Most of the specialty lumber operations are very professional so the failure of these guys was a surprise.
    In short, I purchased about 30 sheets of Sapele and 2 sheets of teak for finish work on my boat. The 1/4 Sapele was fine but the 1/8 was trash. The 23 sheets of 1/8th consisted of seconds with wild color variations and up to 13 lines of knots running across the ribbon sapele. Four sheets were actually 3/32 with paper thin veneer and significant edge and corner damage.
    The teak sheets were truly bizarre. From normal teak color to black and appeared to be turned off tiny stock. Throw away quality.
    The sad part of this is that they trashed a five year project with the garbage they shipped to me. And since it shipped to the USVI I have no recourse but to try to make it work. I paid $500 in shipping to have them clean out their trash.
    Sorry-- My experience is that these are untrustworthy and generally bad people.
    Keith
  13. PAR
    That's lovely Keith, though this is a nearly year old thread.
  14. kaakre
    Thank you Paul!
  15. JakubT
    JakubT Junior Member
    Any new informations about plywood? Any shift since last post is 6 year old?
